RAM failure, location F-11.
Or a trap error depending on the site one reads I guess... lol
Are you trying to boot from a floppy? You dont say you do.
video artifacts and sadmac code is all bad ram. who swapped your ram chips for no charge grandpa?
The "006c" is the chip location, so changes are its F11 + the one next to it.
A"4264" is a 4164 DRAM Chip. Back then they were sensitive to static and heat (compared to today's chips, they are quite robust), so chances are I'm guessing that who ever soldered the board left too much heat to the chip.
But since you say somebody soldered the board, check to see if traces are shorted with a magnifying glass. One hair-thick sliver crossing 2 pads will will a board.
When I replace RAM on a board, I usually replace the whole set.
yes all of the ram is bad… its all no good.… you can screw around and replace one or 2… only 6 months later to have another one or two go bad...
that ram is is the worst. the apple logo'd micron is bad… and yes, that board has already had some ram replaced, but with the same junk that goes bad.
i go through and replace all the ram with good Samsung ram.. and problem wold be permanently solved.
as i said its a big nasty job, i have recently lowered my price for this job.. and its a big nasty job.. but has to be done… there really is no other viable solution.
yep i'll try it today.it could also be the 74ls244's all the ram is connected to, When i assembled and installed a MacGusto II upgrade board onto one of my 512k boards i got something similar and the install guide pointed to one of the 74ls244's being bad (in my case this turned out not to be the problem, it turned out i had a short under one of the ram ic's) So if replacing the ram doesn't fix it try swapping the 74ls244's
Yes, but to clarify does this sad mac occur without floppy in the drive?and i can't boot with floppy because the sadmac !
thanks for reading.
