Does anyone have a quadra 700 schematic? I want to try to resurrect it.
Well my quadra 700 died yesterday. One of those damn Maxwell batteries peed all over the board. Well... I noticed it yesterday.
It ate away a few oscillators/clocks. I've removed a lot of the acid using acetone. I'm surprised that for the most part most of the traces seem to be intact. I've also lost a few diodes, caps, and resistors. Considering how far it went, I'm surprised the damage isn't worse.
I'm mostly concerned about the corrosion at the via's at the moment. It ate the connection points to the first two ram chips. It looks like all of the custom chips are probably intact - some have corrosion on one side of legs, but not the other. So it's possible it may be recoverable. The acid went across the board in about a 1 and a half inch line across the board right up to the video output connector.
