zezba9000 Posted August 2, 2020 Report Share Posted August 2, 2020 Can someone tell me what ceramic cap spec from the image below is. (In the red square). I'm thinking I may have the same issue as this guy: https://www.classic-computers.org.nz/blog/2009-03-29-re-repairing-an-apple-II-plus-clone.htm Where that cap is bad as the voltage around 1v and that guy says it should be 4.2v. Is that cap a "100nF 50v"? If so seems like this pack of caps contains it? https://www.amazon.com/Hilitchi-Monolithic-Multilayer-Capacitors-Assortment/dp/B071P44QBH/ Quote Link to post Share on other sites
bibilit Posted August 2, 2020 Report Share Posted August 2, 2020 10 µf 50v Quote Link to post Share on other sites
zezba9000 Posted August 2, 2020 Author Report Share Posted August 2, 2020 8 hours ago, bibilit said: 10 µf 50v That seems wrong: https://www.quora.com/What-is-the-number-104-on-a-ceramic-capacitor If they measure in pF wouldn't this be 0.1 uF Quote Link to post Share on other sites
zezba9000 Posted August 2, 2020 Author Report Share Posted August 2, 2020 (edited) 100nf = 100,000pf (aka 104) = 0.1uf So the cap I got off amazon is correct Edited August 2, 2020 by zezba9000 Quote Link to post Share on other sites
bibilit Posted August 2, 2020 Report Share Posted August 2, 2020 sorry, you are right, 0.1µf Quote Link to post Share on other sites
zezba9000 Posted August 14, 2020 Author Report Share Posted August 14, 2020 Just continuing this thread here: Quote Link to post Share on other sites
Recommended Posts
Join the conversation
