Alex Posted January 4, 2018 Report Share Posted January 4, 2018 Hello I have a Quadra 950 with no hard drive. I recently purchased an IBM SCSI drive, model DDRS-39130. Unfortunately the drive is 68pin female. I know that there are adapters out there but I am not sure which to get, there are so many for sale here and there that I am left confused. I love in Poland, EU but if needed, I can get this item shipped to the US. If anyone could help I would be grateful. Kind regards —Alex Quote Link to post Share on other sites
Compgeke Posted January 4, 2018 Report Share Posted January 4, 2018 (edited) Any generic passive adapter will probably work, providing the drive will run in 8-bit mode. I personally use ones like https://www.ebay.com/itm/Monoprice-76-SCSI-HPDB-68-Female-to-IDC-50-Female-Adapter/371310538092 however you'll need to look around for ones that ship to your country. I've tried the PCB design ones and while they do work, they can be a bit tall and don't have confidence inspiring stability. I usually prefer these and a terminated 68 pin cable as that handles the whole termination problem and usually comes out cheaper than a device-side adapter + inline 50 pin terminator (since some drives don't like CD termination and such). If you only want to try out an adapter for the hard drive alone, https://www.ebay.com/itm/68-pin-to-50-pin-scsi-adapter-hard-drive/302588084209 would do the trick. Probably cheaper than converting everything in the system to run off 68 pin cabling anyway. Edited January 4, 2018 by Compgeke Quote Link to post Share on other sites
Recommended Posts
Join the conversation
