Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10141 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3972
      posts
    2. Conquests
      39568
      posts
    3. Trading Post
      53126
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1486
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      499
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      46023
      posts
    2. Mac II, Quadra & Centris
      13113
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7963
      posts
    4. 68k PowerBook
      9875
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2672
      posts
    2. PCI Power Mac & Performa
      5881
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13747
      posts
    4. PPC PowerBook & iBook
      8970
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7398
      posts
    2. Newton
      1066
      posts
    3. Software
      17464
      posts
    4. Hacks & Development
      18630
      posts
    5. Peripherals
      14548
      posts
  • Posts
    • Yes! It’s always good to see something come back to life. Well sleuthed!
    • Wading through just about anything to get just a little bit of something hidden therein ain't relaxing. I like to leisurely watch your videos, maybe with a cold glass of lemonade in hand. They're much appreciated by all here I think and thanks much!
    • Mystery solved! Found an old post that mentioned the 280c logic board has 4 x 35v 100uf (check), 1 x 35v 47uf (check), 1 x 25v 33uf (check), and 1 x 25v 100uf (eureka!). I had all of the above in my parts bins, so recap complete.
      My new friend gave me a bit of a scare today after buttoning it up though: Hung on the initial gray screen, even after numerous power-cycles. From my research trying to track down that cap value, I read numerous horror stories about leaking caps causing exactly that behavior on Duos
      Gravely concerned at this point, I opened it back up and started poking around with the DMM and scope. I couldn't find a schematic anywhere and the board is a forest of vias (who knows how many layers...), but while probing around in the DC-DC circuitry, I noticed that "DZ6" was open!  D = diode, Z = Zener I assumed. The little SOT-23 SMD had "8Y" silked across the top, and a bit of googling suggested an SOT-23 packaged Zener diode thusly marked was perhaps an MMBZ5248? That I certainly didn't have, but I contacted a tech I'm friendly with at a local electronics repair shop and he did  Booted right up after replacement. A $0.13 part almost ruined my day.
      This particular failure mode was probably specific to my board, but if any of you are hanging on to failed Duo boards, replacing DZ6 might be worth a shot...
    • I do this with my Macs - it prevents it coming loose when you transit the Mac, the video board socket doesn't hold onto the CRT's neck too well on its own from my experience.   Have you checked continuity from the brightness knob on the analog board?
