Jump to content
olePigeon
QXGA LCD Panels now cheap ... good enough for variable resolutions?
Recommended Posts
One thing I'm having a lot of trouble finding is a generic LVDS/TTL LCD controller board, with the usual VGA/DVI/AV/etc inputs, that can do the following:
  • Arbitrary resolutions and scan rates for the target LCD, programmable by the user not the seller
  • Scaling or pixel-doubling
If anyone has any leads in such a thing I would be incredibly grateful.
Share this post
Link to post
Share on other sites
LOL! I suggested checking for a controller board from the PiVerse yesterday, but I was only thinking about looking on eBay. Checking in with what's been going on in the Raspberry Pi community might be a better idea. @Bunsen that may be a good place widen your search. Who knows, if there isn't a board available, somebody might have figured out how to turn a Pi into one?
Quick check later:
Pi 4 has a Display Serial Interface (DSI) on board and there's a howto for hooking Pi/DSI up to a panel:
https://core-electronics.com.au/tutorials/how-to-use-a-screen-display-with-raspberry-pi.html
Wondering if oddball Mac Video output resolutions/timings might be fed to GPIO, the data massaged on Pi 4 and pushed through the DSI output? Pi might to be able to scale/embed whatever the input resolution/timing in a  might be letterboxed full resolution QXGA (or other) output frame a/o scale it to multiples between input and DSI->LVDS output limitations?
Was looking for info on converting DSI to olde schoole LVDS (if necessary) and came up with:
WAG here is that Pi4 and a shield or two might become a general purpose converter from any given VGA output to any given panel's LVDS input? Dunno about this stuff, but crazy notions come up and I toss 'em back out, but something along the lines of this might sound like an idea worth researching to somebody?
edit: wondering if ancient LCD outputs from Luggable thru the last non-LVDS PowerBook panel might be handled in the same fashion? [}:)]
Edited by Trash80toHP_Mini
Share this post
Link to post
I recently bought a super-cheap LCD/Scaler combo that uses a Realtek-based scaler chip that's ridiculously widespread in the cheap boards. I've done digging on the "RovaTool" software mentioned a lot in this guy's posts and I have been wondering if it's worth trying to tweak it, since its out of the box configuration is less than optimal. I don't have the link handy, but there's actually a tool out there that can program the board without a separate programmer if the board has a VGA port wired according to the reference design. (It can pass SPI through the DDC channel.)
That said, these tools are *extremely* user unfriendly, and are mostly for getting the board to work with specific panels. I haven't found anything on how to tweak the input parameters, which is also a thing I'd like to do. It may not be possible with this chip; it seems to be a very TV-centric device.
Share this post
Link to post
...Well I finally received the LCD controller for my IAQX10S from China. Doesn't work. :(
While the backlight lit, nothing displayed on screen, and according to the EDID info the controller is set with a max resolution of 1440x900 (aka typical "we didn't even bother configuring this LCD controller" resolution).
DumpEDID v1.07
Copyright (c) 2006 - 2018 Nir Sofer
Web site: http://www.nirsoft.net
Active                   : Yes
Registry Key             : DISPLAY\AGO0001\5&11ec779c&0&UID1048849
Manufacture Week         : 45 / 2013
ManufacturerID           : 61188 (0xEF04)
ProductID                : 1 (0x0001)
Serial Number (Numeric)  : 1129197617 (0x434E3031)
EDID Version             : 1.3
Display Gamma            : 1.97
Image Size               : 81.8 X 107.3 cm (53.1 Inch)
Maximum Image Size       : 30 X 23 cm (14.9 Inch)
Maximum Resolution       : 1440 X 900
Support Standby Mode     : Yes
Support Suspend Mode     : Yes
Support Low-Power Mode   : Yes
Support Default GTF      : No
Digital                  : Yes
Supported Display Modes  :
    1024 X  768  60 Hz
    1280 X  720  60 Hz
    1280 X  720  120 Hz
    1280 X  800  60 Hz
    1280 X  960  60 Hz
    1440 X  900  60 Hz
    1440 X  900  75 Hz
    1280 X 1024  60 Hz
    1280 X 1024  85 Hz
I bought it from this AliExpress seller, best stay away from it. :(
Share this post
Link to post
Yuck.
Something I didn't mention about that cheap-o LCD/Scaler board combo I bought on eBay: the eBay listing I ordered *that* from proclaimed it was "NEW", all-caps. Actually, no, the LCD panel I received with it has the worst burn-in I've ever seen. It looks like it might have been harvested from some sort of in-flight entertainment system or something, no idea because reading Chinese isn't a skill I possess, but if I *could* read Chinese then I'd have no problem whatsoever telling you what was statically displayed on it for probably *years* straight.
The seller pretended to be very apologetic and there is a replacement in the mail, but I have this feeling that when it arrives and I discover it's just as ruined as the last one I'll be filing an "Item not as described". Watch yourselves out there, kids.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
