Jump to content
Sign in to follow this
ScutBoy
Pull power supply from SE
Recommended Posts
Is it necessary to pull the whole analog board if I want to get a power supply out of an SE?
I've never had to do it before, and the Apple Service Manual calls for bringing out the whole analog board, but it seems possible to be able to snake it out on it's own.
If that is more trouble than it's worth, then that's fine, but I was hoping to save myself a little work :-)
Share this post
Link to post
Share on other sites
I’d remove the screws that hold the analog board in place, disconnect the logic board and the CRT neck board. That way you’ll be able to swing the analog board out of place without disconnecting the yoke and the flyback... giving you plenty of space to remove the PSU.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
