Jump to content
Sign in to follow this
Iamanamma
Solid State Drive for G3?
Recommended Posts
28 minutes ago, trag said:
Check your display device (monitor, LCD panel) and cable and any adapter.
I tried Macintosh 12" RGB monitor, known to work, on the built in video. Nada.  I tried a Dell Flat screen with a VGA style plug on the ATI card.  The ATI card has ONLY a VGA type connector on it, no Apple.  Nada.  I can grab another monitor, I have several spares.
Now if the video card was originally a PC card and was hacked with one of the "reduced" firmware packages to work on a Mac, then it might need drivers.
Wouldn't know how to answer this, so I took a picture.
Also, it is possible that the video card is in some weird state/configuration where it's trying to drive the display at an unsupported resolution.    You may wish to zap the PRAM (hold down cmd-opt-p-r simultaneously) at power up/reboot.
As long as I have been playing with Macs, you think I would remember to zap the PRAM.  Thanks.  That's next.
Finally, but maybe this should be first, if you have a VRAM module installed on the motherboard, check that it's installed  properly, hasn't popped loose.  Perhaps clean the contacts.
Again, don't know how to answer that. So I took another pic. Also, thanks for the link.  That could be useful in the future!
Share this post
Link to post
Share on other sites
Now that's the first tim THAT has ever happened.  I double checked to make sure I had the right keys pressed down, but I am only hearing the startup chime once.  I am not getting a second chime.  I switched out the PRAM battery.  I switched keyboards.  G3 will start up, I get one chime, no more.  Something is definitely wrong here.
Edited by Iamanamma
more detail
Share this post
Link to post
On 10/4/2019 at 3:06 PM, trag said:
The ATI video card, if it is a Macintosh version, should produce video without any drivers.    Drivers enable acceleration and sometimes additional resolutions, but any video card with Mac firmware should produce images at boot time, without loading disk based drivers.    Hence, I suspect your display device, rather than the video card.
It took a while to find it, but the ATI Rage card is definitely the Mac version.  http://macos9lives.com/smforum/index.php?topic=4257.0 is a lookup of ATI Card part numbers, and mine was on it.  I am still getting no video out of the G3.  I tried zapping the PRAM (which will not chime more than once), resetting the NVRAM and resetting via the CUDA switch.  I looked up VRAM modules, I don't see anything that looks like that.  What I have in my PCI slots are as follows an audio card with telephone jack, a Firewire card, and the ATI Rage 128. I have attached pictures front & back of the Rage card.  There is some yellow residue on the 2 foil squares on the board, but aside from that, everything is looking pretty good. There is definitely something wrong here, and it's beyond my skill set to figure what it is.  I have a couple more beige G3s.  I am going to haul out another and see if I can get it to work.
Edited by Iamanamma
Added pictures and details
Share this post
Link to post
Moot now, but if you have a VRAM module (may be called GRAM in Beige G3) it would be under the modem that is sticking sideways out of your sound card.  Behind the voltage regulator and between the RAM and sound/personality card.
Also moot, but another thought I had was perhaps the 12" monitor doesn't do 640 X 480?   I think there was a small Apple monitor that was fixed at something lower like 512 X ?
Share this post
Link to post
I have a Rage128 as well. Dang good card that's worked in all of my PCI macs wonderfully. I want to get a few more so I'm not playing musical video card all the time though.
I'm baffled by that monitor business as well. Apple Spec says it should support 512 x 384 internally. I wonder if that's just for 8.0. Is there software cutoff for that in 8.5–onward?
Share this post
Link to post
Not moot any more.  Dang thing is acting up AGAIN.  I haven't been using the Apple monitor, I've been using a Dell flat screen.  I pulled out the sound/modem card and the VRAM would go into that small whitish frame, wouldn't it?  Nope, nothing there.
Share this post
Link to post
There should be 2MB soldered on-board—those two big ICs beneath where an upgrade module would go in the white, sideways holder. The expansion will take you up to 6MB total with a 4MB module installed. SO there's enough on the board to support a monitor. Curious that yours still doesn't work with an Apple monitor.
Do you have an older install CD? the 8.0 discs? be aware that the ROM ver. will determine which image will be bootable (I went through several to get my beige MT to boot). The older disc is just my theory about 8.5+ not supporting 512 x 384 any longer, but it's more supposition than anything.
Edited by jessenator
errata
Share this post
Link to post
Any recommendations for a good place to buy replacement IDE/ATA ribbon cables?  It's going to be not fun to thread them through the case like you have to on the minitowers, but if I can pick up a couple for cheaps, it would be worth it to see if that fixes what isn't working.  Would love a line on a new PSU or two as well.
Share this post
Link to post
Are you actually in Warren Ohio?
Anyway the Beige G3's used the old 40 pin ATA cables that tended to be longer and I think you can still find those on ebay. Most cables you see today are the shorter 80 pin type which will still work on older systems but are shorter. Years ago I had to track down a cable for my B&W G3 since it was a custom super long one and needed to be OEM (for the CDROM maybe forget what it was for).
Share this post
Link to post
The 12-inch color monitor does 512x384, and the 12-inch grayscale display does 640x480. I'm around 90% sure system 9 will recognize and work with both on built-in mac video.
Share this post
Link to post
I had all sorts of trouble getting my Beige G3 to install and boot MacOS from SSD until I replaced the 40 wire cable with a newer 80 wire one. You might have to modify the new cable too since the mac doesn't have the key pin removed from the IDE pin header on the motherboard.
The beige g3 tower is also not terribly difficult to mod to use a standard ATX power supply, I have a brand new one in mine. You have to rewire some pins in the power cable and make sure the jumpers are set correctly on the motherboard to avoid damaging it. I followed this guide: https://forums.macrumors.com/threads/atx-psu-conversion-powermac-g3.1739059/
Share this post
Link to post
1 hour ago, Unknown_K said:
Because I am in Youngstown, odd seeing somebody that close here.
Sure is.  It's great to know there's someone else nearby who still uses older Macs!
Edited by Iamanamma
Share this post
Link to post
I have no idea how to modify cables.  Know any good tutorials?
Share this post
Link to post
The thing to know about most (all?) power supply connectors is that they are a plastic housing filled with pins.
The pins and the housing are sold separately.    The pins crimp onto the ends of wires.   Then the pins snap into the housing.   There's usually a little "latch" or prong (or two) that hold the pin in the housing after it has been inserted.
So, if  you want to rearrange the wires on a connector, you can carefully remove the relevant pins from the housing (depending on the brand/model of housing there are often dedicated tools available, though improvising works too) and insert them in the hole to which you wish to move them.
Of course, new pins can be bought and crimped onto the ends of cut wires and new housings purchased.
The trick in the latter case is knowing which housing/pins you need.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
