Jump to content
Sign in to follow this
Kai Robinson
Powerbook 180c chime, then death chime
Recommended Posts
Hello! I'm a veteran of 68k mac land, having had a IIci and LC475 in the past. I picked up a 180c on ebay and in the process of testing it, initially I found that it just went to a white screen, no chime. I pulled it apart and found several bent pins on the internal connectors, particularly the top case connector and an expansion ram board. I straightened the pins, plugged it all back in and... Well, i videoed the results :
https://youtu.be/5FGlqCzD6wE
Idea's? It also looks like here's a to-220 package regulator on the board that's been badly resoldered...
This is on mains only, 15w ac adapter, no battery damage or battery present.
Share this post
Link to post
Share on other sites
Welcome Kai!
The "sandwich" of the motherboard, CPU daughterboard and memory modules in PowerBook 1x0 can be very prone to bad connections and can often cause errors in a pristine unit, and especially in one that has visible damage.  Another common failure point is a fuse near the DC jack that can be jumpered with a wire; but if that's gone it won't start up at all.  Also if you're using an Apple 7.5V power adapter, the caps on these can go resulting in a "weak" incomplete startup such as this.
I'd pull the HD, third-party RAM, clean the contacts with electronic solvent spray, and lastly reseat the CPU paying attention to the shims on the casing that it's securely aligned.  Does the HD spin up, and if it does does the 180c attempt to start up off it?  Check your power brick; ensure it outputs the right voltage, under load.
JB
Edited by Byrd
Share this post
Link to post
Thanks for the detailed reply! There is no hard disk in the machine, nor is there the cable or cradle either. Is there a capacitor replacement guide for these machines? I noticed that the AC adapter is only 15w, and not a 24w, as is specified for the 180c, is that enough to make a difference like this?
Share this post
Link to post
...and it's just been rendered moot - the IDC cable that links the top to the bottom has basically come away - the internals look like a gibbon has previously opened it up - there's nothing securing the cable to the pin end :(
Any chance i can get a replacement of just that board from other powerbook 1xx series, or is it a specific part to 180c's?
Share this post
Link to post
Ah crap, Kai :)
Sounds like some dodgy DIY work carried out on that poor 180c.  No wonder you didn't have a display!  Can you post a pic of the cable and missing board?  It should be a universal part to all colour 1x0 PowerBooks.
Going back, is your power adapter the 7.5A/1A rated unit - that's for Powerbook 100s (and I think Mac Portable), you need the higher rated amperage units to successfully power up later more power hungry 1x0 models.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
