Jump to content
Sign in to follow this
BadGoldEagle
SE/30, IIsi ROM, 32bit addressing woes
Recommended Posts
Hi all,
A month or two ago I bought a GGLabs SIMM for my SE/30. I had the seller flash a custom image and I think something went wrong with the programming (the ROM image works otherwise fine with Basilisk II). The SE/30 freezes when the Floppy EMU is connected in HD20 mode and System 7.5 refuses to boot (sometimes 7.1 as well) even on 'real' hardware.
I don't have a ROM programmer for this SIMM. Does anyone have one and is willing to flash this SIMM for me? All I wanted is the IIsi ROM with RAM check disabled, nothing else...
Thanks!
PS: I'm in Europe.
Share this post
Link to post
Share on other sites
I found an archive of Gamba's website: http://home.earthlink.net/~gamba2/os8_se30.html. I did the modifications and the Mac is now booting fine. But now there's another problem...
I have 32megs of RAM in this machine and the system folder is consuming 27megs. I don't think this is normal. What should I do?
Edit: Apparently 32 bit addressing turns itself off every time I shut down the system... I don't have a PRAM battery but I thought the system kept the settings if it was still plugged in... I just rebooted it (without powering it off) and now the RAM usage is normal.
@Cory5412 @Bunsen @wthww @Gorgonops Could you please change the title of this thread to "SE/30, IIsi ROM, 32bit addressing woes"? Thanks!
Edited by BadGoldEagle
Share this post
Link to post
You still have to turn on 32bit addressing in the memory control panel, otherwise the system folder will show up as using up any RAM beyond the 8MB barrier.
Share this post
Link to post
Yes, I knew that was the system's behaviour when 32 bit addressing wasn't on. I just thought it was on... System seems to be running fine now.
I just need to design an external battery holder now because I don't want to take it apart every time I want to use more than 5megs of RAM...
This is completely off topic but I thought about designing a holder that uses the security slot of the Mac as a support. If I make a fake battery with two terminals, slot it into the real battery slot, run some wires to the back of the case and insert the holder with a fresh battery inside the slot, I should be golden. That way, I can take it off whenever I'm not using it and not risking any leakage..
Share this post
Link to post
Done!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
