Jump to content
Von
SE/30 Power Supply: Recap or ATX?
Recommended Posts
Hi All,
One of my SE/30s is getting its motherboard recapped and this is what is PSU looks like with leaky goo:
The machine has a new old stock analog board and will have the following when completed:
  1. Micron Video card with grayscale adaptere
  2. Daystar 50 mhz accelerator that goes plugs into the socketed motherboard
  3. Asante Ethernet
Given this planned configuration, would you recommend getting the PS recapped or heading down the path of hacking in an ATX power supply? FWIW, reecapping is not in my skill set but I think I could follow along to do the ATX if it is just soldering some wires.
TIA for the input!
~Von
Share this post
Link to post
Share on other sites
I have pretty much the same setup minus the video card which I'll hopefully install on top of the Ethernet card someday. My PSU was recapped and everything's fine as far as I can tell.
I'd say recap it, and if you experience any problems in the long term, you can still sell it and make a profit.
Share this post
Link to post
I created a list of caps to replace on Mac 128/512/Plus analog/PSU boards some years ago, including DigiKey replacement parts:
https://docs.google.com/spreadsheets/d/132RwzC8HM5ask-BdY_31txErOCwJDSkz099GY2XLpE0/edit?usp=sharing
Has anyone created a similar Excel file of replacement caps for the SE/30's PSU (both ASTEC and SONY) as well as for the Analog Board?
Share this post
Link to post
Not an Excel file, but a DigiKey list for the Analog Board, I created:
https://68kmla.org/forums/index.php?/topic/29440-capacitor-list-for-se30-analog-board/&do=findComment&comment=318183
Also a DigiKey list for the Sony version of the power supply:
https://68kmla.org/forums/index.php?/gallery/image/1215-se30-sony-power-supply-recapped/
Share this post
Link to post
Late response, but - OMG thank you! I have been searching for a list of Mac 128/512/Plus analog board replacement parts. I don't know if all the part numbers on DigiKey will still be the same but this is a fantastic start.
Share this post
Link to post
Sorry to necro this thread, but I'm interested in JDW's question:
Has anyone compiled a list of replacement caps for the Astec SE/30 PSU? Or is this a matter of, better off replacing it with a Seasonic?
Edit: I'd really just like to save time, but I'm happy to record what I find in mine and come up with a replacement list (which will need editing/refining from one more in the know).
Edited by jessenator
Share this post
Link to post
As I said in my SONY PSU recapping video on YouTube, I don't recommend wasting time recapping the ASTEC since the failure rates of those have historically been higher than the SONY PSUs.  As such, I personally think you would be better served with either a recapped SONY PSU (they do crop up on EBAY, not recapped), or just go with the SEASONIC.  I would say the amount of work required to recap a SONY PSU probably is about the same as the SEASONIC mod, and you can see my SEASONIC video on YouTube about that.  The added benefits of the SEASONIC is more power and all new components.  The benefit of the stock PSUs are no added fan noise.
Edited by JDW
Share this post
Link to post
@jessenator  I've had no issues recapping Astec PSUs in the SE and SE/30 and I think they are good power supplies.  I'm not sure there is any real evidence that their "failure rates have been historically higher." - If there is a pre-existing problem just recapping might not fix the particular issue but I do it as preventative maintenance.  Voltages have been rock solid afterwards  Attached is the list I compiled along with the particular mouser caps I used.  I found it pretty easy to work on and there aren't that many caps so it wasn't that expensive either.  You'll probably want to make sure the caps are the same in case there are different versions of the PSU (and bear in the mind the Apple PSU pictured at the top of this thread looks similar to the Astec on the outside).
Astec PSU.xlsx
I've also done the Seasonic retrofit.  Recapping was definitely easier but if you're going to be running a half height 3.5" drive and more than just an Ethernet card, the Seasonic is probably a better choice.  It's harder to find the Seasonics at a reasonable price now though.
Edited by superjer2000
Share this post
Link to post
Astec PSU.xlsx
Thanks for providing your capacitor list in Excel format.
In all the years I've been on vintage Mac forums, I've read more first-hand reports (as well as an abundance of rumor and speculation too) of Astec failures than SONY PSU failures, and it was based on that I put forth my own words on which PSU may be more reliable or less reliable.  Some of the wild speculation probably assumes SONY to be better due to the brand recognition over Astec, which of course is only speculation and shouldn't be used to make any final determination.  Unfortunately, due to all the drive crashes and data loss in this forum through the years, I cannot point you to specific first-hand reports (which I know I have read in the past in this very forum, among others), which say the owner of the said Astec had a failure whereas none of the SONY PSUs in their possession had failed.  I've also read that some Astecs were not repaired even after recaps, but I've not read so many reports of that with the SONY PSU.
What can I say from my own personal experience?  Well, I don't have that many SE or SE/30 power supplies to make a meaningful data pool.  I only know that my SONY was dropping voltage due to faulty caps, as evidenced by the fact that after recap, it started working fine again.  I also have an Astec, but I've not recapped that because instead of recapping that I bought a SEASONIC.  And thank your for sharing details of your experience with the SEASONIC, as you were one of the individuals who inspired me to do my own SEASONIC mod.
All said, I think if one has a stock SE/30 without a lot of upgrades bogging down the PSU, a recapped stock PSU should suffice, assuming it has no problems outside the caps.  And the reason I say that is because it runs without a dedicated PSU fan.  The SEASONIC is great when you need more power, but the fan inside can be heard, especially if you have a rather quiet analog board fan and no spinning platter hard drives.  And even though the fan in the SEASONIC is activated by temperature, once the SE/30 has been on for even just a few minutes, the SEASONIC fan tends to come on and stay on in my experience.  The fan isn't too obnoxious, but I wish to mention it since most people who know the stock fanless PSUs may be a tad surprised by the fan noise (however minor) in the SEASONIC.
Share this post
Link to post
I keep meaning to clean up the lists I've made and post them as I've done quite a few analog board/PSU recaps that I've made lists for.  I will say overall I've had good luck with all of the Astec PSUs I've encountered and recapped across a number of Macs.
Share this post
Link to post
I look forward to your forthcoming posts! :-) And truly, once its posted (assuming no more data loss in this forum from hard drive crashes) it serves as a great information resource for others.  That's really my own drive to video what I do and put it up on YouTube.  I often wish somebody else had made such a video, but since there aren't any (or at least, not of high quality and adequate detail) I make my own.  Admittedly, it takes a LOT of time to do that, however. But another reason I do it is because I've become terribly forgetful in recent years and having a video not only helps others but reminds me very clearly what I did in the past.  Anyway, thanks for all your contributions to this forum!
Share this post
Link to post
It's funny you say that as I have noticed the same thing - I think it's a matter of keeping everything straight with work, family, projects at home and then these side computer projects.  There is a lot more going on than when I was young and could seemingly remember everything.  I've taken to writing down notes on any of the more complex projects I work on, including how I've troubleshooted particular problems as otherwise when I try to think back to it weeks or months later, it's just fragments.  I keep an Apple IIe on my desk to document these items.
Share this post
Link to post
Thanks for the additional thoughts, gents.
My current supply does work, but a due diligence recap is a definite. There may be a replacement down the line. I think a recap now would be more economical (for me personally). (<$20 for parts vs >$50 for a Sony psu and parts —a rough estimate, as of this morning).
And I don't have anything going into it beyond a scsi2sd, macsimm, and 32meg of RAM, currently.
This might change when/if I manage to track down a PowerCache or a DiiMo, but that's not an immediate future goalpost. And by that point I'll probably just go the seasonic route, barring its discontinuation and larger price hike.
Share this post
Link to post
9 hours ago, jessenator said:
superjer2000 let me know if I've missed something. I just took your excel doc and put it into google drive: https://docs.google.com/spreadsheets/d/1nNdyF3AmS5j5TuW6KUp-8z5YyOCSNTk1GoV-aE7BsHU/edit?usp=sharing
At a really quick glance it looks good. You should be able to verify your getting the right parts by making sure what  you put into mouser returns the same parts as the screen shots of my order I included. This is again assuming there was only one version of the Astec PSU.  I'll be doing another in the next couple of weeks as I just grabbed an SE/30 with an Astec.  Very clean machine with just a bit of cap leakage on the motherboard. I always order about 5 to 10 x the number of caps I need Build an inventory and prices go down substantially with 10x of a single item with Mouser.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
