Jump to content
JRL
PowerBook 180 no power (x2)
Recommended Posts
So 2 of the PB 180s I picked up lately don't power up. One seems to make a small "blip" noise about every 5 seconds or so, the other has the screen turn on for about <1 sec. This is with both main batteries removed.
Are there any fuses I should be on the lookout for on this MB? Thanks!
-Jeff
Share this post
Link to post
Share on other sites
First I'd check the PSU, and recap/recalibrate it under load.
There is a fuse near the DC jack on the motherboard that often dies, and can be replaced with some thick gauge wire; I did have a link but am not on my usual computer right now to find.
Share this post
Link to post
Are these PB 180 or 180c?
If PB 180c they need a good 3 ampere (24W) power supply and will only start for 1 sec with less than 3 ampere.
So did mine.
Share this post
Link to post
Verified that the psu isn't the problem - correct output. I'll keep a lookout for the fuse, thanks!
@MikeatOSX It's a 180 (not 180c)
Share this post
Link to post
I found the female power connector soldered to the 180's mainboard to easily cause a slack joint. It can be damaged by bending the contacts, the solder pads in the mainboard can become loose, and also the contacts may corrode from the 3 A uptake of the PowerBook. My first PowerBook was pulled from my knees by the cable and fell just onto the plug. Both the cable and the jack broke. I fixed the power adapter with a new cable and a new plug (a flexible rubber stage quality microphone cable is appropriate for this purpose, and you can choose from many colours), and also soldered a new jack onto the mainboard. That solved any power problems in this machine for quite a long time, until all of the batteries died.
Share this post
Link to post
Is that voltage taken under load? Thats where it really counts.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
