Jump to content
Sign in to follow this
codyNC90
Powerbook 1400 16mb ram module upgrade to 24mb
Recommended Posts
I have a 16mb ram module for the 1400c and I cannot find any 24mb ram modules. Would it be possible to add the 4 needed chips and some kind of connection at C3 to change 16mb to 24mb? It looks like there are some online warehouses that have KM48C2100BS-L6 chips.
Share this post
Link to post
Share on other sites
I would get a datasheet for those memory chips.  That will give you a pinout -- which pins have which functions.  Then get out the multimeter and trace out which pins those resistors connect to and what they connect them to.    Are they doing something simple like pulling up/down chip enable?   If so, you'll need to install the two unpopulated resistors probably.   Or are they doing something more or less complicated?
The unpopulated capacitors are almost certainly straightforward.  They're just there as voltage smoothing ("bypass") and when you install the next two chips, install the corresponding capacitors to smooth the voltage for those chips.
Edited by trag
Share this post
Link to post
I guess that was a silly question on my part. IIRC Apple only supplied 12MB and 16MB factory slot cards. Yours must be for the user slot given its size. Did they offer memory upgrade cards as well?
Share this post
Link to post
The other option would be to use a "donor" 16MB card and grab the chips and resistors/capacitors from it. I've heard of this being done with Toshiba notebook RAM modules in the late 90s.
Edited by FacnyFreddy
Share this post
Link to post
I have some extra RAM modules that I dont need (they are two and add up to 52 megs of ram I believe). I dont need them since I have my 1400 maxed out on RAM on another stick and have a g3 upgrade.
LMK dont need them
Share this post
Link to post
LMK dont need them
Did anyone take you up on this? I have a 1400c/166 with the minimum memory configuration of 16MB and can't find memory modules anywhere. I tried to message you directly but the site would not allow me to.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
