Jump to content
Sign in to follow this
BlueTrepidation
Color Classic Brought Back to Life
Recommended Posts
Hello everyone,
Today I recapped and washed the motherboard in my Color Classic. Before the machine would not power up when pressing the power key on the keyboard. The machine now posts. Next, I opened the faulty hard drive. I noticed the heads seemed sticky in the parked position. I dropped the heads off the edge of the disk to gain access to the inside of the lower arm. From there I could see a smudge mark where a rubber bumper makes contact. After adding a coating of oil to this location the hard drive came back to life! Now I have an OS to boot into. Last, I'm stuck at the point in the attached picture. Looks like the finder is trying to initialize the boot disk? Anyone know a way around this? Shift boot didn't do the trick.
Thanks,
A.J.
Share this post
Link to post
Share on other sites
"It WAS the harness. It took a couple of weeks, but I got another CC and another 630 harness. I first switched the two chassises [?] to see if the analog board had anything to with it; it did not. (That was a mistaken "newbie" assumption on my part.) I then wired the new connector harness and installed it in the original CC. It worked like a charm - no "disk initialization error". Furthermore, the picture on the monitor is beautiful, very little border and no distortion (hi-res upgrade).
I checked the old harness with a meter and it seems that all wires conduct just fine. Maybe it was a crossed wire or a loose connector.
I did a regular VGA upgrade on the newer CC, but it has fat black borders. I might try the capacitor fix. I have a 575 board in it running 7.5.1 (I think). I might upgrade it to a PowerCC too, or install a CD, or a Zip drive, or a... - I'm heady with success here!! :-)"
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
