Jump to content
iMac G4 700MHz - 10.4 or 10.5?
  • Please log in to reply
47 replies to this topic
#1 HFTaylor12
HFTaylor12
  • 6502
  • LocationCentral Michigan
Posted 11 December 2016 - 01:31 AM
Hello,
I have the original iMac G4, 700MHz with a 15 inch screen. I'd like to start putting it to a lot more use, and that had me wondering about an OS. I have 2 options: 10.4, or 10.5 (unsupported). What do you think is best? I plan to do web browsing, YouTube (with PPC Media Center) music, word processing... basic stuff like that. Tiger has the advantage of speed, however Leopard supports more software, and newer versions of software. For web browsing, I used to use Leopard-WebKit but now I'm using TenFourFox as my default browser, no matter which OS. So what do you think? Tiger or Leopard? I'm curious to hear your opinions.
Power Mac G5 | iBook G4 | Mac mini G4 | iMac G4 | iBook G3 "Snow" | iBook G3 "Clamshell" | iMac 1.83GHz C2D
#2 TheWhiteFalcon
TheWhiteFalcon
  • 68030
  • LocationArizona
Posted 11 December 2016 - 01:37 AM
10.5 will run like crap on that hardware. Stick with 10.4 and keep your expectations very, very modest.
Desktops: Cube, iMac G4, 128k, 512k/Plus, SE/30, IIsi, Q700 PVT. Laptops: 180, 3400c, Pismo, TiBook, iBook Clamshell, MBP 15", MBA 13", Unibody MB, '15 MBA13 Portables: MP 130, 2100, eMate.
#3 HFTaylor12
HFTaylor12
  • 6502
Posted 11 December 2016 - 01:57 AM
OK. I find that 10.4 runs really well, though. If Leopard is even 60% as fast as that I'm happy.
#4 TheWhiteFalcon
TheWhiteFalcon
  • 68030
  • LocationArizona
Posted 11 December 2016 - 02:09 AM
Leopard really needs 2GB of RAM or more to be happy if you're planning to use it.
#5 rsolberg
rsolberg
  • 6502
  • LocationVancouver Island, Canada
Posted 11 December 2016 - 04:46 AM
I have Leopard on my 800MHz 15" iMac G4 and it's pretty sluggish even with the maximum 1GB RAM and a fast SSD. Tiger is far more usable.
68000: Mac SE Superdrive, 68040: Mac Colour Classic "Mystic" w/VGA mod
#6 Macdrone
Macdrone
  • 68020
  • LocationKelso, Wa
Posted 11 December 2016 - 06:56 AM
10.4 so you have os 9 also.
Lots O' Macs, but now thinning the lots.
#7 HFTaylor12
HFTaylor12
  • 6502
Posted 11 December 2016 - 01:52 PM
Thanks everybody. I think I'll go with Tiger based on what you're saying. I'm ok with a little slowdown for Leopard features, however this big of a slowdown seems too big. Thanks!
#8 bunnspecial
bunnspecial
  • 6502
Posted 11 December 2016 - 04:45 PM
I'd disagree with that statement(typed from a dual 1ghz Quicksilver with 1.5gb RAM that runs Leopard as its main OS).
I don't like Leopard with under 1gb, but anything above that will generally be okay. It does run decently well on G4-upgraded beige G3s, which max at 768gb.
One of the biggest handicaps to Leo on all in one systems is usually the GPU. I'm at a big advantage in my Quicksilver in that I can(and do) run a Core Image card. On beige boxes you can run a Radeon 7000 or Radeon 9200, both of which are a big improvement. In NWR PCI towers(B&W and Yikes!) you can even get Core Image if you want to go to the trouble of flashing a card.
All that aside, I've been perfectly content with Leopard on my 700mhz eMac, which is very similar to the 700mhz iMac.
#9 HFTaylor12
HFTaylor12
  • 6502
Posted 11 December 2016 - 06:56 PM
I agree with this post. My 1.33GHz iBook G4 runs Leopard really, really well with 1.5GB of RAM.
#10 TheWhiteFalcon
TheWhiteFalcon
  • 68030
  • LocationArizona
Posted 11 December 2016 - 07:07 PM
Which 1.33GHz iBook? The 12"? If it's that model of course it runs Leopard pretty well; it has a Radeon 9550 which is Core Image capable.
#11 HFTaylor12
HFTaylor12
  • 6502
Posted 11 December 2016 - 07:09 PM
12 inch. It actually ran Leopard decently with 512MB of RAM.
#12 RhianB
RhianB
  • 6502
Posted 11 December 2016 - 11:52 PM
 I agree with this as well. My Dual 1Ghz QS powermac runs 10.5.8 just fine with 1.5GB ram and does not have a CI supported GPU - still running the GF2 MX 32mb AGP card it came with. In fact, aside from boot up, most everything about Leo in terms of speed is on par with Tiger and software support is so much better with Leo.
Certainly the single cpu will be slower with chubby apps on the imacg4 but from using my QS when it had the single 733mhz cpu before its D1ghz upgrade, I think the imac should still be quite usable for modest everyday sort of stuff. So yeah, try it and if it sucks, reinstall Tiger lol.
Oh yeah, this is my first post here. Hi everybody, I'm Rhian :)
Edited by RhianB, 11 December 2016 - 11:56 PM.
#13 HFTaylor12
HFTaylor12
  • 6502
Posted 12 December 2016 - 01:02 AM
Honestly, I am totally OK with a slow OS. I use a Power Mac G5 as my main Mac, so I'm not spoiled by all of the new fancy Intels. So what some of you might see as "slow" could be fast to me. We probably have different definitions of "usable" and "unusable" too. Some here might know that I seriously was going to use a G3 Clamshell as my only Mac for a week... but I couldn't get Tiger installed, so that didn't work out. :( Honestly, if I can load apple.com in 15 seconds or under I am happy. So I'm totally fine with "slow".
I'll also point out, I'm not using this as a daily driver or anything. I just want a computer that can handle some light web browsing, email, word processing, and maybe some other software (my main reason for wanting Leopard).
EDIT: Also, I get the "macOS Sierra Theme for Leopard"! I'm sure many of you have heard of that. Really awesome... there is almost no way to tell your PPC is outdated.
Edited by HFTaylor12, 12 December 2016 - 01:11 AM.
#14 HFTaylor12
HFTaylor12
  • 6502
Posted 12 December 2016 - 04:27 PM
Well, in about 20 minutes, I will install an OS on this iMac... I think I'll go with Tiger, but if any more opinions can get in before then I will read them!
#15 Cory5412
Cory5412
    Daring Pioneer of the Future
  • Administrators
  • LocationArizona, USA
Posted 13 December 2016 - 05:05 AM
If you already have a newer/faster web-faring machine, what if you just install 9.2.2 on that iMac? Then, you can run 10.5.8 on that G5 without worrying about having Classic Mode on it.
Alternately: 10.3 should be fine on that hardware.
How much RAM does that iMac have?
#16 bunnspecial
bunnspecial
  • 6502
Posted 13 December 2016 - 01:25 PM
I've yet to see a situation where Panther ran noticeably faster than Tiger on any given set of hardware. To me, it's hard to make an argument for using Panther in any situation anymore as the software availability for Tiger is many times better.
#17 HFTaylor12
HFTaylor12
  • 6502
Posted 13 December 2016 - 09:17 PM
Well, here's one of my reasons for going with Tiger... this iMac has 512MB of RAM. Now, I remember 512MB working well on some other Mac models for Leopard. But I think that in this case I should go with Tiger.
#18 Cory5412
Cory5412
  • Administrators
Posted 14 December 2016 - 12:34 AM
I had a TiBook and a blue-and-white G3 when 10.4 came out and later replicated everything I'd tried on those on a Pismo.
I have all the weird problems with Macs and my Windows installations run flawlessly for years on end -- but I had so many problems with 10.4 when it was new. It was worse at literally everything and I always ended up reverting back to 10.3.
It pretty much wasn't until I had an Intel Mac that 10.4 was semi-stable, and I moved to 10.5 the literal instant my preorder of the new version arrived at my house.
Later, I would do up a bunch of G4-Intel machines for a K12 environment with 10.5 client and server. It 10.5 was "acceptable" on a group of 700MHz iMac G4s, IIRC with 512M of RAM, but this was also literally ten years ago (well, eight, but who is counting?). It ran "fine" but it was by no means "very good" -- the machine that really struggled was a Power Macintosh G4 dA/466 with either 128 or 256M of RAM. It ran, but it was not pretty.
Honestly, either is going to be slow. I'm betting if you put tenfourfox on any OS on that hardware and try to go to most modern web pages you're going to find yourself swapping to disk. I'm not sure that it makes a material difference which version of OS X you run, because even 10.2 really wants a half a gig if you can give it.
Perhaps what you should do is just get a bunch of different things and try them? Heck, try Linux on that machine, too. If you want to run it on a network, that's going to be your safest and most up-to-date bet.
#19 HFTaylor12
HFTaylor12
  • 6502
Posted 14 December 2016 - 09:18 PM
I'd like to! I've never really tried Linux before. Once I tried Debian, but my computer wouldn't boot up correctly after installation. Do you have any good recommendations? I'd really, really like a GUI with this also. ;). Also, I need something that supports a fully up-to-date web browser, 'cause OS X can do that (TFF).
#20 Cory5412
Cory5412
  • Administrators
Posted 19 December 2016 - 07:05 PM
If I didn't make this abundantly clear before, I'll go ahead and do so now:
If you need to browse the Internet, I recommend you set this computer aside and buy a modern one. Old systems like these are a big risk on the Internet, because they're vulnerable to being used as part of a service amplification attacks, and because problems often go unfixed.(among other things, it has been discussed at length on this forum).
It's less about the security of your individual information (which most attackers don't want, or they'll just use phishing to get), and more about creating an Internet that's less likely to see spam and have DDOS attacks.
There are some, but not many, and no good centralized resource for hardening old PPC versions of OS X. The US Government has some hardening information, but it was published when 10.5 first came out and doesn't have updated information about, say, installing the relevant patches for, say, ShellShock, which Cameron Kaiser published.
So, my advice?
Get an Intel-based Mac, or some other sort of Intel-based computer on which you can run the newest versions of Mac OS X, Windows, or an up-to-date Linux (or other) OS distribution.
In terms of Linux on PowerPC, I don't have any specific recommendations. I haven't looked at that for years, because to me, a Mac is better used as a Mac. If you want to use OS X for some OS X apps, disconnect it from a network that can be routed to the Internet, or run OS 9 on it.
A modern, patched linux will be much more secure, but it will reveal the same thing tenfourfox will on either OS: Something this old and crusty and slow is going to be a bad experience on the web. You aren't going to minimize the badness by using an older OS that purports to use less resources because....
1) Older versions of Mac OS X generally don't consume less resources. Mac OS X will expand to fill the computer you put it in.
2) Most modern web pages are simply so huge and complicated that any of them will overwhelm an old Mac.
Remember, it has been a few years since smartphones became faster than the Quad G5, and the Quad is already over twice as fast as something like the dual-core 2.3, dual 2.5, or dual 2.7. Those are themselves something like four or six times faster, in total, than a G4 like this.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
