Jump to content
Cloaked Alien
128MB Magneto-Optical Rewritable
Recommended Posts
As mentioned earlier the only time it doesn't spit out the disk is when I've got my partition software open.
The program is/was HDT Primer Personal Edition, I'm currently using it to "low-level format" one of the MO-disks. We'll see how it works after that.
Haven't flipped any DIP switches or the likes yet and I've got no MO drivers installed in the system.
Share this post
Link to post
Share on other sites
Success! \o/
However the disk shows up like a regular hard drive rather than having a custom icon, but perhaps that's not a bother to begin?
.. gonna try to install that MDF 2.3.8 driver kit again.
Eureka! After HDT has had it's way with it I can re-init it using the MO Disk Formatter. It now has a proper icon as well =)
Share this post
Link to post
Well, that might be. But I wouldn't rely on it since it seems like buying a new MO drive would have me paying out my *rse. Zip-drives are easier to come by =)
But yeah, of course I'll put it to use!
.. now I just have to figure out how to make my CD-drives work with this machine and then I'm only one Ethernet adapter away from making my old SE/30 take over as the new primary machine ;)
Share this post
Link to post
A "new to me" MO drive is only $30 from the link I posted earlier.  Incidentally, I just got my second one in.  Looks like a clean pull from a server environment.  I don't think they've ever been used.
Edited by olePigeon
Share this post
Link to post
I must be getting blind, I can't find that link. But at that price it's certainly worth getting a second one to connect internally in my retro pc =)
It's the machine I use to transfer files to my SE/30. I've got an internal ZIP in the PC and MacDrive Pro and I've got a SCSI ZIP on my Mac.
Share this post
Link to post
Hi CA,
 I have some SCSI 128MB, 230MB and 640MB drives as well as MO disks for them. I'll sell you a drive and some MO-discs, if you like. I can boot from them but they are finicky, for example, the MO-discs often need to be mounted if they are not the boot disk. I'm in Switzerland, though, and the postage will also probably be hefty. I haven't yet found an extension that works better than no extension.
Kind regards
aa
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
