Widget drive
On your video, I never hear the brake release. After the drive comes to speed - about 5 seconds or so, you should hear a "clunk" as the brake releases and then the drive should start to seek. When it seeks, it will make very distinctive "squeak" noises.
I don't know if the lack of brake release is because you are only providing power to the drive, and not any data signaling from the Lisa.
I think this has been covered, but you can read about adjusting the brake in Pina's book.
Yes. This is not going well. Sometimes the brake releases, but after that not much happens.
I'm not sure if this disk will work ever. But I will try it on a Lisa one day. That will not be easy.
I think it might be because the disk isnt getting up to full RPM? I know the servo controllers of HDDs are smart enough if it senses a problem with spindle speed, the rest will hang until it comes up to full speed.
Inside the Widget is a glass scale used for head position feedback.  The scale is attached with glue and 30 years later on many Widgets the glue has failed.  This  commonly results the glass breaking causing all kinds of issues, the worst of is tiny fragments of glass loose inside the enclosure.  I fear the screeching noise you hear is due the glass causing a head crash…
Rick
BREAKING NEWS!!!!
With some spare parts I could test my Widget drive. And.... It is alive!!! The Lisa boots up nicely from it. So my efforts to revive it a succes!
See pictures:
I will report later about the "spare parts". I will also start a new subject about a new disk. That doesn't boot......
I thought your Lisa had no logic/mother board?
Edit: I love Lisas, but I cannot justify spending US$1000 on a computer I can't upgrade/repair (10 000 volts on a CRT).
@tanuki65
Repairing the Lisa is not in this post. I will report later about this.
Just like to inform all followers of this post that the Widget is working. Thats GREAT news if you realise that it was completly stuck and inclear if it would work ever.
What the heck are you displaying that on? The picture is too dark to tell but it doesn't look like a Lisa, even with the front bezel missing.
Yes. It is easy. Just 5 or 6 small screws reachable from inside. I washed them in a bath with washing powder and they look nice and clean now. I also removed the two bottom plates to clean them.
Ok. A nice video to end this topic! I have build in the widget drive. It still gets its power form an external PSU. A plain normai cheap power unit from an old computer. I ripped of all the extra wires and made a custom plug. Just with some glue and ductape.
I first switch on the hard disk and then the Lisa. Works fine:
http://www.youtube.com/watch?v=ZboBCbx62us
The disk was revived bij turning it manually for a long time so the grease around the bearings softened.
But to see if it really worked I needed a working Lisa. I acquired one with a defective disk, floppy drive and video board. I used the other parts, like CPU, IO and memory cards to revive my own.
hey at least you got it working.
The lisa is one of those machines that I don't have any attachment to, and its up in the air whether I would own one or not.
I think I will leave the Lisa collecting to the purists because if I had one I would hotrod the hell out of it.
