Lisa 2 / Macintosh XL floppy drive ejects disk immediately – troubleshooting help - HDD advice
Hi everyone,
I’m currently restoring a Lisa. So far We have repaired battery damage (corroded traces), rebuilt parts of the power supply (replacing transistors and capacitors), and fixed the video board. The system is now mostly working, but we are currently stuck on the floppy drive.
After cleaning the drive, pressing Apple+2 it now accepts the disk, but immediately ejects it. So I’m unable to verify whether the issue is with the drive itself, the I/O board or with the disks I prepared.
At the moment I’m unsure:
  • whether the drive is faulty, or
  • the I/O board works
  • if I might have created the disks incorrectly
I was wondering if there are known diagnostic methods or tools to test the drive.
For example, are there any equivalents to something like a test ROM, Eprom, that could help verify if the hardware is working properly?
Also, my machine has ROM version 3A (so it should behave as a Macintosh XL, if I understand correctly). Does this mean it cannot read original Lisa disks and only supports the newer MacintoshXL-formatted ones? I’m not entirely sure about this and would appreciate confirmation.
At this point, I would also consider adding an HDD/SD-based solution instead of relying on floppy disks. Do you have any recommendations for compatible devices or products that work well with this system?
Any suggestions on how to properly test the floppy drive or create compatible disks would be greatly appreciated.
Thanks in advance!
Additionally, would it make sense to downgrade the ROM version in this case? If so, do you have any advice or best practices on how to safely perform the downgrade?
Congratulations on your Lisa progress!
You're correct that boot ROM 3A means a Lisa set up to work only as a Macintosh. In particular, this ROM works with another ROM (the "video state ROM") that controls video timing and gives your Lisa square pixels instead of the slightly rectangular ones that were their original shape. Most of the diagnostic software out there requires rectangular pixels, so it will be better to revert this modification if you can in order to do further troubleshooting.
It's possible to get the appropriate ROM chips and program them yourself, though you may need a fancy ROM programmer for the video state ROM. I haven't attempted it. Alternatively, I would email the person who runs Vintage Micros and tell him that you want a ROM set for returning your Lisa to ROM H/rectangular pixels.
Once you have these ROMs, you just swap them into the CPU board.
There is no test ROM that I'm aware of. Most diagnostic utilities for Lisa are loaded from a floppy or a hard disk. There is a method for "side loading" BLU from a serial port (refer to the manual), but this is a utility for managing disks and not for diagnostics. It may still provide some clues about what the problem with your Lisa is.
I think BLU probably requires rectangular pixels, but you should check.
This is a worthwhile approach. There are several options, but I recommend the ESProFile. It's cheap and it works well. There are probably online shops that sell ready-to-use units for a relatively low price.
There is no real difference between 400K disks for screen-modded Lisas and original Lisas. Some Lisas had a modification that introduced an 800k double-sided drive, but these can still read 400k disks.
I have no specific testing suggestions myself. How are you making the disks now? When your Lisa ejects floppies you try to boot from, what does it show on the display?
If your disk is ejected, probably an issue with the System Software, or the disk itself.
how have you created the disk ? you are dealing with a 400k disk drive, so are you using a 800k disk and only one side of it ? you cannot use any 1.44 Mb disk.
so in the end you will need a 800k drive to create the good boot disk,
What disk are you trying to boot from? You will need a MacWorks or MacWorks+ boot disk. This is a Lisa formatted 400K disk. If you try to boot the Lisa from a Macintosh system disk, she will just spit it out like you describe.
Also there is a version of the ListTest disk that works with the 3A ROMS and will perform floppy disk testing.
Thank you so much to everyone for the detailed and very helpful reply!
Under normal circumstances, preparing and burning EPROMs is not a problem for me.
I'll study better how to manage the Lisa's one
Interestingly, my Lisa actually has a physical switch installed that should theoretically allow toggling between rectangular and square pixels, though I am not using it at the moment.
I read in the BLU manual that it should be able to run even with my ROM 3A, so I would prefer to stick with this ROM for the time being. Once I get further along, I will evaluate if it is worth the effort to swap the ROMs and revert to a version prior to 3A.
My plan right now is to proceed step by step:
  1. First, I am going to repair the keyboard. This will at least allow me to type commands without struggling.
  2. Next, I will connect a serial cable and attempt to sideload BLU to the Lisa. I noticed BLU has a diagnostic tool for floppy drives, and I'm hoping it will help me understand why the machine fails to read disks. At this point, I am still not sure if the problem lies with the floppy drive mechanism, the I/O board, or if I simply prepared the disks incorrectly.
  3. If I still can't get anywhere, I will look into getting an ESProFile and try booting from there. I have tried searching for one here in Europe, but I haven't been able to find one yet.
To answer your questions about the disks and the boot behavior: My Lisa has a 400k drive, and I am using old SD (400/800k) floppy disks. To create them, I used a GreaseWeazle connected to an old 1.44MB PC floppy drive. I took the MacWorks XL files in .dc42 format, converted them to .dsk using DiskCopy2Dsk, and then wrote them to the disks. I did the exact same process for LisaTest.
I know that using a 1.44MB PC drive is not ideal for writing variable-speed 400k disks, but I honestly don't know any other way to do it right now.
When I try to boot, here is exactly what happens: after the machine starts, I press Apple-2 and it asks to insert a floppy. I insert the disk, the drive seems to read it for about a second, but then it ejects it immediately. Absolutely nothing changes on the screen and no error message appears.
Thanks again for your guidance, I really appreciate it!
Are you sure the drive’s head is not dirty ?
Using « olds » disk is not ideal, as many are contaminated, and once the head is dirty, the drive will not be able to read a good disk.
Cleaning the head in between is not a bad idea.
Only the boot ROMs are EPROMs. The video state ROM is a PROM and may present more of a challenge.
Your plan sounds like a good one to me.
I've never tried to make a Lisa disk with a Greaseweazle, so I don't know how well it can work. There's a chance that simply making disks with BLU will work better for you.
Rather than use Apple-2, what happens if you do this. During the self-test, press the space bar a few times. (Other keys may also work.) The Lisa will show the STARTUP FROM... menu after the test completes. A floppy disk menu choice should be visible: if not, that's part of your problem. But if it is present, insert the disk first, and then after a moment select the floppy boot option. What happens next, and does anything appear on the screen?
With a few exceptions, nearly all non-HD 3.5" diskettes were double-density, and as best I can tell, the magnetic media are the same for DD and SD 3.5" disk formats (same coercivity).
All double-density 3.5" diskettes are decades old, though...
Thank you so much for the detailed advice — it's really helpful!
My plan for now is to first connect the serial cable and try to get BLU working, so I can at least have another path to boot the system. In parallel, I'm also rebuilding the keyboard, which is taking quite a bit of time but is necessary. I also plan to order an ESProFile, so I'll have an additional option to boot from a working hard disk image once the machine is more cooperative.
Once I have a functional setup — at least via HDD — I'll tackle the floppy drive issue more carefully, along with the possible ROM/PROM replacement. For now I'm deferring those problems until I have a working serial connection and a functional keyboard.
Regarding your suggestion about the STARTUP FROM... menu: after pressing Apple+2, a small menu does appear at the top of the screen with something like "Insert disk" (or similar wording). I insert the disk, the drive seems to read it for about a second, and then it ejects it immediately — with absolutely no change on screen and no error message. So the floppy option does appear in the menu, but the disk gets rejected every time.
(I hope that are only the floppies written in the wrong way!)
Any thoughts on what might cause this behavior?
Thanks again for your patience!
I'm not familiar with this, though I've noticed that your Lisa uses the "internationalised" three-language phrasing, so maybe it's different to the English I'm used to. Is it possible for you to make a video of what you're experiencing?
I'm glad if my comments are helpful! It's always nice to see another Lisa be recovered.
