A couple years back I was given a Powerbook G4 1.67ghz 15" (a1138) from a friend http://www.everymac.com/systems/apple/powerbook_g4/specs/powerbook_g4_1.67_15_hr.html.
I used for a bit but it would often overheat because of too much space between the heat sink and CPU & GPU. I bought some shims to bridge the gap with conductive copper but taking the motherboard in and out of the case caused it to stop working. It must have flexed too much. Also the unit was unplugged for a couple of months before I was given it and the PRAM battery wore out and are nearly impossible to find replacements. For the last couple of years it's been neglected in a basement and I was hoping to get it in working condition again.
Besides the same motherboard, what other G4 motherboards could I use and would they have a different more easily found PRAM battery? Did other boards have same issues with space between heatsink and processor? Is eBay the only option for replacement parts?
Any info would be appreciated.
