SuperMac Spectrum can’t enable acceleration
Lycus
Hello, I just bought a Supermac Spectrum card, and I can’t figure out how to get acceleration enabled. It’s greyed out in the control panel, the card is powered by a TMS34061
It has a 1987 copyright date on it. 768KB RAM on the card.
Oddly enough the card says it is a Spectrum, no numbers. 1.9.1 ROM.
Have a picture of the card and what the ROM revision is plus the OS you are using?
There are a few different revisions of the Spectrum brand.
The OS is 7.5.3, ROM 1.9.2
Card I can’t find a picture of anything like it besides mine.
That card is old as dirt and pre accelerated video I would think.
I would think that except for the fact that it has a TMS34061 on it, also was sold to me as accelerated.
I have a Radius 8 bit accelerated card somewhere but it has lines down the screen, I think it's got bad RAM, and it's ZIPP so that's extra fun.
Did you install any earlier drivers? Before 2.7.5 the software had a separate control panel and Accelerator INIT and that would interfere with 2.7.5.
I did not. Only used 2.7.5
I pulled out my Radius card and it’s doing this
RAM issue?
That card is not accelerated. Only the later SuperMac cards that used ASICs supported acceleration.
The TMS34061 does not support any pixel operations, it’s just a „dumb“ framebuffer controller.
Awesome. Thank you. I know the TMS34020 and stuff is actually a CPU so that’s why I got confused.
So I’ll have to fix my Radius
Yep, that’s a totally different beast. I’ve got two Formac Nubus cards with one of those on them and they allow for QuickDraw acceleration.
Side fact: the hardware acceleration in Marathon only works with the specific video chipset in the LC/Performa 630 as far as I know. No other Mac and no Nubus card supported that.
I thought it was just 1.0 that was like that but 1.2 allowed QuickDraw
