I have one of each of these super drives-- UJ-815-C, UJ-825-C. One's from a Powerbook G4, and the other from a G5. I also have a 50 to 40 pin adapter.
I'm guessing either one would work, but I read that these drives are set to master and you need to set the hard drive to slave.
I read somewhere that if you remove pin 28 on the IDE interface for the superdrive that will allow cable select to set it as slave.
Has anyone done this?
