Successful LC II Capacitor Replacement
Mike Richardson
Banned
68030
I have successfully replaced every capacitor on my LC II motherboard.
The sound is fixed! Sweet, glorious, 8 bit, 22 KHz sound now emanates from my LC II without distortion.
Perhaps some other problems are fixed as well, ones which I did not notice, but primarily my concern was the sound.
That's awesome. [:D] ]'>
I think I might have to do the same soon. I'm getting a squealing sound from the speaker. Is this what happened to you?
Just did the 3 10uf caps closest to the sound chip. I lost one of the traces on the 4th, however, my sound works properly now.
Make sure PDS cards still work. I think some of those are related to the PDS card.
the Xceed ColorFusion i´ve got in there works, as everything else does... mine only seems to suffer the sound problem...
