Slow SPI (Half Speed) BlueSCSI DB25
F4 and F4Lite BlueSCSI use an active termination system which shouldn't cause cross-talk when used mid chain.
Some models have resistor packs that are removed to disable termination, and others use bus switch chips to move the terminator resistors out of circuit. Removing the resistors packs physically disconnects the signals so there can't be any crosstalk, and the bus switches perform effectively the same function with a solid state mosfet switch.
My 180c should rest easy then :)
thank you for the work you do on this as well as the portable hybrid project!
Yeah, those F4 and F4lite boards with the transceivers look like they address my criticism of the original design. I don't know enough about the termination stuff to have an opinion on it, really, but from the point of view of my earlier points, nice work, @androda .
I'm still waiting to know about a BlueSCSI user that had one failing because of its design
Consider your wait over. I had a pair of them in two separate SE/30s, installed on the same day and used for the same amount of time over a two month period.
One morning I powered the two machines up and poof! BlueSCSI down. The thing is entirely dead. It cannot be powered up and cannot be reflashed. Therefore, it is beyond saving. I promptly put it in the bin and bought a better SD-based SCSI device.
With its dyed-in-the-wool reliability issues and generally underwhelming compatibility (completely unusable on my Quadra 650, for instance) I have just about all the ammunition I need to justify not wasting any more money on BlueSCSI. It is interesting that there are some variants emerging with solutions to the issues highlighted by @cheesestraws, however.
If you still had it I'd like to get my hands on it to diagnose the failure (send me a DM if you do). There are other components on there - maybe as simple as the LDO failed. I'm not saying things never fail - I'm saying that this issue being discussed hasn't been the root cause.
Yes they've been out for quite a while - and I've talked to you about them. There are many boards and forks, check them out!
MacSD has "pull up" and "pull down" modes, which I cant find any reference to in a spec (seems that would only do 1/2 of what termination is described as doing). FPT is also not in the spec and wouldnt that overdive the MCU as it's done internally? I donno - I'm not an EE.
You may know "pull-up" as active termination. Two of the five regulators on MacSD are for this purpose. Here's more about FPT and termination in general.
While old HDD did have removable resistor nets, it's not a great user experience.
Signal integrity doesn't care about user experience. This is one way to eliminate removable nets:
I didn't dismiss it, I agreed with it. It's the exact same design as RaSCSI.
Then my comments apply equally to RaSCSI: It shouldn't be used mid-chain either. Cloning open source designs is not without risk.
I'm not concerned with your board's driver strength or longevity. However, your users should be aware that BlueSCSI termination is never "off". Therefore, in multi-device buses, BlueSCSI belongs at the end of the chain and other devices should have their termination disabled. Documenting this in your manual would reduce "SCSI voodoo" and headaches for everyone involved. Do you plan to do this?
I do own a RaSCSI, what procedure should I take in this case when using it with my 180c with an F4Lite BlueSCSI in it? This would be with just the internal BlueSCSI and external RaSCSI connected. I have had some inconsistent issues with the BlueSCSI not working sometimes when the RaSCSI was connected, although those cleared up when I changed power adapters for the PowerBook.
It sounds like it may have more to do with termination power rather than actual termination, but @androda could probably give you a better answer.
@erichelgeson
The conversation we had about termination took place nearly three months ago. What have you done since then to let your users know about the problem?
I actually don't have a RaSCSI, and might not be able to help very much. PowerBooks don't provide termination power to the external SCSI bus, so the RaSCSI has to be powered by a USB cable in this scenario to my understanding.
It's a little unclear why changing the power adapter for the powerbook could help. Maybe termination power (for the internal BlueSCSI) was running too low for the system to be totally happy when talking externally and the new adapter shored things up.
May have been a coincidence but the first adapter was an aftermarket 2A (the 180c needs 3A) that I was overdriving. It did boot the system but my OEM 3A is better suited
I have seen the BlueSCSI reliability argument (and inevitable @erichelgeson pile-on) play out several times and it's getting tedious.
Frankly, most BlueSCSIs use a knockoff bluepill to begin with so I never assume they're going to be ultra reliable. They're an affordable option to replace failing HDDs and for that reason they're useful.
I have not lost a single BlueSCSI to this point (though I had a knockoff bluepill fail as I was flashing it), but if I ever do have one fail, I will just pop the SD card out and build another. That's my attitude and I think it's fine?
Then don't participate in it.
If you have data contribute it. If you do not have data, do not.
I deliberately cite standards and datasheets because these are not marketing materials and they allow my conclusions to be verified independently of my own opinions.
The original BlueSCSI design is defective hardware, per the standards, and the BlueSCSI peddlers are knowingly selling defective hardware as good.
I'm actually pleased to see discourse with datasheets etc., as opposed to generic statements, and I hope this can stay civil and result hopefully in improvements to the BlueSCSI.
I can't help but participate when every other BlueSCSI thread (a project I'm interested in) is hijacked in this way. I've seen the discourse with datasheets at least three times now, the issue is well understood. Frankly, I could say the same thing to you: don't participate in it.
As for your frustration with Eric's responses, bear in mind your own. In this thread alone you suggest he should be ashamed of his work, call him insecure and a cult leader, and
St. Eric Helgeson, the Only Person Who Understands SCSI On The Internet, YouTube Approved™.
Don't view this as a personal attack, I like you. But yeah it's tedious.
There's a huge number of users that just want a single device in their Macs and don't care about termination.
The good thing here is to have different solutions for different needs, and for different budgets... There's people (like me) that just enjoy more building themselves a BlueSCSI or RASCSI and using what they built, instead of just purchasing a finished device. I made for myself several and my only issues where with a couple of bad bluepills.
The bad thing is to have to see here so many personal issues and hate messages that aren't positive in a hobbyists forum...
Then the correct thing to do would be to document the limitations of the hardware so that users aren't risking their data, wasting their time and casting blame where it doesn't belong.
I think it's reasonable to expect that they update the BlueSCSI documentation to reflect that limitation, sure.
But yeah agreed. I have no time for personal vendetta stuff.
Maybe there should be a pinned BlueSCSI thread that outlines hardware concerns and limitations.
Yes, I totally agree that every xxxSCSI alternative deserves independent and unbiased reviews, exposing pros and cons.
This information belongs in the manual of the product. Still waiting to hear if @erichelgeson will put it there.
If anyone would like to defend hanging a resistor net off the middle of the bus, I welcome all debate.
It's always a bummer how these threads go. A thing I have to remind myself a lot is "what am I adding, how am I helping?" and I think several of us lost sight of that here.
That said, I do think we also need to be mindful of context when we bring this these kinds of things up. People who have been around for a long time will remember "security patches" and perhaps more recently "iomega zip" -- poor examples for me to set, I'm aware.
This thread may not be the venue for it, whether that means the venue is "github" or the venue is a new thread in, say, hacks/dev, but it does appear the technical criticisms have been substantiated and should be looked into.
