Thanks
bigmessofwires you are the man
Yes I think that I will probably just solder some wires to the bottom of the external connector through hole nibs and route up to the second drive.
I still can not find the bottom of my external floppy case.
It is lost in the years of no eject gears.
I have one of your floppy emulators and enjoy it.
I have an idea for a board redesign on it though, I was thinking that the buttons and the card slot could be put in line along the width of a standard floppy slot that way it could be installed internally with a cable extension for the display to be mounted on an L bracket under the front of the compact mac centered on the drive slot above. I will get around to doing a sketch of the idea and post the images here.
