Yes the hard drive is upside down in the SE/30. Looking at other old Macintosh II computers this was not the case. Macintosh Classic computers also have the hard drive right side up as well.
I think this might be a major design flaw in the SE/30 computers for putting those old fat hard disks upside down.
Personally from messing around inside the SE/30 my guess is it was done just to keep the cable shorter and non-twisted. Besides this, there is really no point for the decision from what I can tell.
They probably made the goof of putting the scsi plug on the board backwards and fixing that spec was to hard and costly, so they flipped the HD instead.
Seems strange, but the SE was their first Compact with a built-in HDD. The SCSI controller/external connector orientation setup was inherited from the Plus, so it may be as simple as that.
Does the SE use the same drive carrier? Too lazy to look at the explodeds. :lol:
