I carefully removed all the caps on my SE/30 motherboard this morning, and had good luck all the way up to C3.... which I either accidentally lifted, or was eroded away by a leaky cap.
Does anyone know an alternative location for the second pad that I can jumper to? Or should I try connecting to the via?
Also, there appears to have at one time been a part at Y1... what do I need to replace that with?
Thanks again!
Thanks again!
