I'm not sure this is the best solution, especially with modern Macs. Even with the Mac 128K Apple was installing heat sinks to help pull heat away from the delicate electronics and radiate it into the case where convective air would then exhaust it. The Apple III itself was inside a giant heat sink which actually kept it cool despite being much maligned as the cause of its failure. This is why I think the PSU in the SE actually runs cooler than the exposed components on the original analogue boards. Notice even the flyback transformer in the SE is surrounded by a heat sink as well.The Mac mini's case has very little ventilation to start with, and with all the components close together, it certainly doesn't aid airflow. If you did that, you might find cooling becomes less of a problem.
The Mac mini, being derived from PowerBook technology is designed to rely on sophisticated heat sinks to cool it. My MacBook fan hardly ever comes on unless I'm doing something processor intensive. Take that delicate balance apart and air may not cool it as effectively. Certain components may actually get hotter once contact with the heat sink is removed – and ultimately it's the component we're worried about.
The real problem is inside the SE case. Essentially he has created an environment which may be outside the mini's specs. Apple says the highest operating temperature is 95 degrees (f). This means that if you use the mini in the middle of the Iraqi desert on a table in the sun, even if you hang all the parts on a string dangling in the hot desert wind, it's still operating outside of Apple's specified tolerances. So no matter how much air he has moving around the individual parts of the mini, if the temperature inside the SE case is above 95 degrees, then he's risking failure. In fact, while Apple may rate the mini for use at 95 degrees, I would be surprised if they ever expected it to be used continuously at that temperature. Doing so can only shorten its life versus running it at standard room temperature of 72 degrees. And, the mini runs significantly hotter than the SE, meaning the inside of that case is going to reach 95 degrees much faster than it would with just the SE hardware (and the SE was rated at 104 degrees!).
So I'm back to, he should probably put a fan in the case, even if it's temperature controlled – set to 90 degrees to automatically come on. So a silent fan that only comes on when it has to would not be bad at all.
