If this was during the low-level format then you are likely to have turned your drive into just a curious lump of metal and plastic.During the format, the mac accidentally got unplugged and on restart hd setup doesn't recognize it again.
[:O] ]'>.... and you were so close! :?:I guess it is going in the trash.
Yeah, but it doesn't show up in Hd setup anymore, have to try another program i guess.Try low-level formatting it again; SCSI drives as a whole don't die if you botch a low-level format, you just have to low-level format them _again_. That's because the drive firmware is stored on a chip instead of on the disk.
Not much opportunity to try another low-level format, really.hd setup doesn't recognize it again
I took that to mean he was already using a patched version.HD SC Setup (patched)
Try Anubis 3.01, it is quite recent (works perfectly wih ATTO Silicon Express IV) and available here:Yeah, but it doesn't show up in Hd setup anymore, have to try another program i guess.
Yup, at least with Quadra, I don't have nubus powerpc to try it there ;-)ooohh... so it boots even with the 1.65? good to know...
Yes, I noted in my post that I saw that after the fact.I took that to mean he was already using a patched version.HD SC Setup (patched)
