Hi all,
I recently purchased a SuperMac Thunder II GX 1600 for my Mac Quadra 950. It works, using the 13W3 to VGA adapter I took off my SparcStation 20. It's running under Mac OS 8.0, and the SuperMac software is installed (downloaded from Internet) as well as the Apple "Monitors" control panel.
I'd love to run it at 1600x1200, but my monitor (Dell 2007FP LCD) only does 1600x1200 at 60Hz exactly.
I've selected a few monitors from the configuration which looked like they would have 1600x1200 support, and (after rebooting, which is annoying) some do. However, I haven't found any which output the 1600x1200 at 60Hz, so my Dell LCD won't show the signal.
Does anyone know:
Doug
PS: It runs fine at an odd resolution like 1300-something x 1024, so it's a small improvement already.
Does anyone know:
- If there is a monitor in there which is configured to send 1600x1200 at 60Hz?
- If there is a way to explicitly tell the card somehow to send 1600x1200 at 60Hz?
Doug
