Mr Fahrenheit’s conquests
I was wondering. I used to have one of those (with scanner), but the print head developed a temperature sensor problem in the cyan tank, I was moving across country during the shutdown, and it got recycled. You no doubt know what a new printhead costs. I’m now using its older sibling, an 8400.
Can it print on cardboard or are you sticking something down?
I leave mine on 24/7 which certainly has helped with print quality. Prior to about a year ago, I would shut it completely off when I wasn't going to be printing anything, and upon turning on, I would always have blobs of solid wax clog things up and make a mess of prints, resulting on hours of cleaning steps etc. These are really meant to be left running 24/7. Also, using ANY wax ink blocks that aren't officially Xerox cause lots and lots of problems, even if using one for a different Xerox 'by accident'.
I have found this printer can easily print on 130 lb cover cardstock, which is 350gsm. Quite thick stuff, and the straight-through feeder works just fine grabbing it. Nothing jams inside, comes out nicely. I set the print media to 'glossy' just so that the printer knows it's not printing on regular paper, so that perhaps it helps bond the was a bit better to it. Seems to work fine.
That is interesting — about the card stock I mean. I must give the heavier stuff a try,
I leave mine on 24/7 as well, since the off/on cycle is just so wasteful. You can, however, set the sleep timer to 30 mins, using the web-based utility, so that saves on a good deal of the power usage.
In working order, they are fabulous printers, especially for print graphics like what you see on those boxes. Photos, not so much. So, my being hostile to paying $7.99+ for Hallmark pieces of cardboard has led me to print occasional birthday cards, at least for lesser mortals in my circle, though using proper card stationery, and they look store-bought. I also printed some images of lithographs on the 8400 a while back to see how well that would come out. The reproduced art looked fantastic; in fact, it was frameable.
It’s a shame the technology has been retired by Xerox. It has its charms.
I bought the Xerox 8400 on kijiji before I moved, back in London (ON), from a printing firm for all of $40. It had printed 57 copies, I think it was, in its life with them, so it is fair to say I got a good deal.
Yeah, I do have mine on a power saver, but I think I have less aggressive settings than 30 minutes. Probably 90 or 120.
I use a scoring board to put bends/folds in cardstock.
Here you go:
If you're in Canada, this is the link: https://a.co/d/0UkEAIW
