Seeking insight: SE Superdrive display
Hello!
I'm afraid this is my very first post to these forums, but I expect I'll be here a lot from here on. Be gentle. :)
I was recently lucky enough to acquire a Macintosh SE Superdrive. I originally thought it did not work whatsoever, and had planned to use the shell for another project, but I was delighted to find it chimed and chugged when I plugged it in and turned it on. So now, obviously, I want to get it working with original hardware (or as close as I can manage).
Unfortunately, the display has no picture, and while I've done a little sodering and rewiring here and there, this is well beyond my ken. Plus I'm a little gun-shy about the potential shock from the CRT.
A local shop that was willing to look at it quoted me $400 to get it working again, and I was hoping some of you fine folks might have some better suggestions for me.
Picture attached for posterity - please ignore the chaos of USB hubs and wires for my usual setup.
That's good it shows some life, the SE are the cockroaches of compact Macs and usually reliable, yours might have a bad caps in the PSU or analogue board. Silly question but have to ask - you have the monitor brightness all the way up? You can test the PSU voltages from the floppy port - see pic. The PSU can also be replaced with brand new innards.
$400 is a lot to pay for a $200 Mac, only do if the tech is quoting for a complete overhaul - all caps and labour, maybe a SuperDrive check as well.
