The thing you will want to watch for is parasitic inductance and resistance in the leads. That looks like a switchmode regulator which can have very high peak currents at high frequencies. Notice the parts are clustered tightly together connected by big fat traces. You can *probably* get away with moving things around a bit, but make sure you use heavy enough wires and keep them as short and direct as possible.
Are you trying to make room for a longer hard drive? You might see if you can find tantalum or ceramic capacitors that are low profile enough to fit under it without moving them.
THX, yep, I figured that tank farm and coil are the ElectroCrud for conditioning/converting the battery's power input, I'll either not be using a removable battery at all or using a different form factor battery mounted 90 degrees counterclockwise from that connector. That depends only upon electrical compatibility of the replacement battery and the successful lopping off of about 1/2" to 3/4" of the, all but empty, PCB peninsula where the FDD connector is right smack dab in the way. [:O] ]'>
HDD was a good guess! :approve: Make that a CD-ROM drive poking out the left side and you'd be right on the money! [}] ]'>
