I got my MacSD! And I‘ve managed to fit it to my LC475, inside the case, with a BlueSCSI (which I prefer for its CD selection method - I know the MacSD can read CDs, it just doesn’t do it quite as elegantly from my perspective.) But MIDI! That’s the real party trick.
I want to use the MacSD for MIDI and Synthesizer, and I believe that this should be possible and that I can mix it into the Mac’s mono audio. The MacSD is detected by OMS - but then it crashes immediately. Not “I just need time to think”, proper frozen mouse frozen. I’ve tried multiple times, same result every time.
The documentation doesn’t have any example configuration for Midi and Synth - so I’m not sure if I’ve set it up right. I’m a little confused that it doesn’t seem to require a SCSI ID to be provided. Does anyone have a working configuration file for Midi and Synth that I can crib?
