Here is a curious issue I am having. I turn on the IIci and the board gives a chime, then a gray boot screen but the corners are still there and then the death chime comes in.
I can replace the RAM with different models and get different results. The NEC for instance give a different error than the Samsung for instance.
If I put in a ROM and leave the jumper in place , I'll get just a gray screen. With the jumper removed (which is the correct way with a ROM installed), then I will get the death march almost instantly
with a black screen.
Due ti the fact that there is POST and the chime first, I like to think that I got a Memory SIMMS issue.
But the placement of the ROM snd resulting error makes me think that there is maybe an issue with the ROM or ROM SIMM?
What is you guy's thought on this?
