Mac plus probing signal at J8 pin 1
gkmaia
Anyone out there with an open Mac Plus who could send an oscilloscope plot of J8 pins 1, 3 and 5?
[SIZE=1.4rem]Specially pin 1 which is video out. Probing it I just got a noisy LOW signal.[/SIZE]
[SIZE=1.4rem]I was [/SIZE]suspicious[SIZE=1.4rem] of my LAG IC but after probing V & H sync I got clear pulses at 60HZ & 22KHZ which seems to be ok. [/SIZE]
That will help me heaps to rule out a motherboard issue and focus on the analog board.
Your video signal is kinda weak. Might need to look into that. Check the CRT Neck board for a shorted video driver transistor, and/or check the logic IC on the analog board where the video is gated through.
Also probe the video signal on the logic board as well.
it seems as if the signal for the video is being damped for some reason.
It could be. You would have to try a known good PAL from another logic board if you had one.
otherwise, you would have to burn a new PAL which I dont think the bitstream files are out there for the Plus.
