Mac IIci replacement diode
Recapping another IIci board and noticed that one of the small black diodes is missing from Q3. I assume it is the same diode that is on D3, D4, D5?
I need to purchase a replacement, but haven’t figured out what to purchase. Any help would be appreciated.
I have attached some pictures for your reference.
Just checked the board that I picked up for my IIci. Q3 is either 1AMW or 1/4MW. D5 on my board is marked 5DW. Same with D4, etc.
FWIW, a “Q” reference designator is usually a transistor, not a diode. Hopefully the part markings that volvo242gt provided will help.
Thanks for all your help and also the clarification between the “Q” and “D”, I will order one up and get this fixed.
I appreciate it.
Update one this. I actually found the tiny transistor in the bottom of the case. I soaked it in IPA, cleaned it up and soldered it back in place.
Mac IIci is up and running again.
Thank you community for all the information.
Wow, those things are tiny.. but same thing, lost one on the carpet, and low and behold i found it lol., unreal.. glad you found yours too
