I have a IIci that boots, but has strange audio issues and random lockups
After a full recap, it boots, without chime.
if the Simple Beep is selected as the alert sound, the machine locks up when an Alert comes up. switching to a different alert sound and putting audio to mute allows me to receive an alert without freezing.
also, the TCP/IP control panel for example freezes the machine when opened. tried 3 different system 7.5 HDs with the same effect. a few other softwares freezes it too, but I couldn't find a link between them. Norton System Info CPU/FPU and Video benchmarks all run fine.
With the Cache Card installed, it will power up but won't show any video. the card was recapped too.
could this be a bad audio chip corroded by leaky capacitors?
I tested continuity around the board without issue
I had one CPU pin bent during repairs, but managed to straight it up . continuity tests appear OK. the bent pin is pin 124 on the CPU, labeled DS on BOMAC schematics. (datasheet says [SIZE=11.6023px]Data Strobe[/SIZE][SIZE=11.6023px] DS [/SIZE][SIZE=11.6023px]Indicates that valid data is to be placed on the data bus by an external [/SIZE][SIZE=11.6023px]device or has been placed on the data bus by the MC68030).[/SIZE] if it were cut, could the machine still boot and display video, but freeze with a Simple Beep ?
