M4984 G3 Imac 233 mhz Rev B preservation steps
I have a new to me M4984 Rev B that turns on. I understand there are some common problems that affect the longevity of the systems. To that end I opened the machine up but everything looks clean. All caps are in shape w no leaking.
Are there known capacitors I should replace anyway?
This is the first and only mac I've owned so assume I have no history of the machines or philosophy of design.
Thanks
Bob
Noting the sheer amount of caps and expense replacing these, if it all looks OK I’d keep everything on hold unless issue. Maybe check PSU/PAV voltages when on to confirm things look OK. Stubborn startup issues and crashes will indicate failing caps. A lot of rev a-b iMacs it’s the flybacks going now too, usually obvious though with random noises and jolts in normal use.
