During VCFW I picked up a LaserWriter IIg for free. When I first got it, I had the dual flashing paper jam and paper out lights, indicating that one problem that every Canon SX printer has, the “Error 50.” Naturally, I pulled the AC power supply board out and replaced the 22uf cap, along with the 100uf cap in there too. I haven’t replaced the Triac.
However, even after reassembly, I still get the same error. Furthermore, I seem to have picked up a new problem, namely that the 24V power doesn’t work. I don’t know if said power issues were happening before or after the recap.
The upper fan (which runs on 24V) is not running, however the lower fan (which also runs on 24V?) is running. However, they may be different voltage rails. I still need to test if there’s 24V going to the fuser, and/or the upper fan.
Any advice on what to do? My current next step according to Laserjet II/III repair is to replace the DC assembly, but I wanna check in and make sure it’s not something really stupid.
