Interware GrandVimage 24-21s Info Dump
@zigzagjoe, Did you get to GrandVimage 17AV performance testing?
If you have MacBench or other Benchmark results, share it.
I didn't do any serious testing. It has similar performance to the figures from the first post as it uses the same chipset, though I'm not sure if it can use Nubus block transfers or anything that might result in more bandwidth when framebuffer updates are happening.
