Well you should get death chimes with no ram installed at all, so pull it all and see if that gets you anywhere?
You can try exercising the reset and interrupt switches a bunch of times. I once had a stuck one, took 3 days of troubleshooting and a bunch of voltage readings to find that problem. Now I make sure to hit those up before anything else!
What is worrisome is the floppy drives firing off like crazy. That doesn't sound too good. :/
My original 1MB SIMMs look pretty similar to what you have posted, except everything is flipped 180deg. I suppose different SIMM designs exists rather than a standard single design. Try looking up the datasheets on the chips and compare that they are functionally the same.
