Help with portrait / full page displays
That's a good thread.  For me, an FPD with a Mac Plus is kind of a Holy Grail.  A big monitor with one of those early systems, is just cool.  I have a number of FPD cards for the Plus, I think, with the BNC connector.  Anyone know of a way to go from BNC to something more modern?  I'm guessing finding a FPD with BNC is like, impossible.
Got it!  [;)] More like a lot of work for very little real progress on that front. Dropping that project in the To Be Continued bin real soon now. I have an adapter board project to finish up while I wait for crystals and capacitors to arrive  .  .  .  after I figure out what I need of which. So it goes.
Oooooh, I am going to read the hell out of that thread once I get home and the kids are down. Assuming I don’t just collapse.
I think the last mystery is the cable standard for going from the DB-9 Radius FPD, Rasterops Portrait Clearvue/15 (turns out that is the full name) to the DB-15 Mac standard video.
Soon(tm) I can get you a pin out for the Radius FPD. I’ve got an older one that has the pinout marked on the PCB insides. At least I assume it’s older one, the entire front chassis is cast metal!
Well heck, isn't this the cable you are trying to get working with your other thread @Trash80toHP_Mini?
http://archive.retro.co.za/mirrors/68000/www.vintagemacworld.com/radius/590-0057.html
Seems like you could then just use a DB15 to VGA adapter to get to the LCD.
Sadly, doesn't appear to be any DB-9 to DB-15 cable pinouts.
Cable Part Number:
590-0057
Assembly Number
590-0057
CPU side connector type
DB-15
Monitor side connector type
1 BNC
Built in Monitor ID
1152 X 882
CPU Side Pins
Monitor Side Pins
CPU Side Connector
DB-15
Monitor Side Connector
Single BNC
Pin 01
Ground
Inner Pin
Green Video
Pin 02
Not Used
Outer Pin
Green Ground
Pin 03
Not Used
Pin 04
SENSE ID 0
Pin 05
Green Video
Pin 06
Green Ground
Pin 07
SENSE ID 1
Pin 08
Not Used
Pin 09
Not Used
Pin 10
Ground
Pin 11
Not Used
Pin 12
Not Used
Pin 13
Ground
Pin 14
Ground
Pin 15
Not Used
That's where I found the pinout in the first thread, before the BNS woes thread. I'm wiring straight from the TPD/SE card's output pins to VGA cable. Signing off on the third installment soon.
Curious about the full page displays and scan lines ATM. If the scan is "horizontal" turned "vertical" in Portrait orientation I'll be playing with FPD cards next. Anybody know the answer to that offhand or will it depend upon maker/model.
Well, got two new cables, one of the Portrait display, one for the FPD/gs.
Radius display power light comes on, but it won't display an image.  I can see nothing on the screen at all.  My first thought is that it is at the wrong display settings, something that isn't compatible with the Portrait.
But when I plugged in the FPD/gs, it seems to have automatically gone to the proper settings, 640x870 (or something close to that, I don't remember exactly).  Portrait cable is showing a little road rash or something on one side.  Perhaps it is defective.
The FPD/gs does show an image, but it is scrunched horizontally.  The size adjustment on the back work fine for vertical, but horizontal barely does anything and the image is pretty far from the edges.  Anyone have any ideas about this?
I got a VGA to EGA adapter from Amazon, but haven't tried the regular FPD yet.
Do the refresh rates of your FPD and card match? Seems there were 64, 68, and 75 kHz versions. The card for the 75 apparently drives a Macintosh portrait Display too, if that archive can be believed.
+1 and believe it. That archive is the gold standard. The formatting can be problematic which is why I said it was a mess of (a mass) information on compatibility. I may or may not still have have a printout of most of the Q&A,. They were FAXback system documents someone archived. OCR wasn't perfect back in the day, but the information should be correct. The text was either proofread carefully or gathered later from a Radius internet source.
Radius FPD Monitors.
There are basically two types of FPD Monitors. A two row, 9 pin connector, and a three row, 15 pin connector (VGA). The FPD Monitor with the VGA style connector came out in 1991. Every FPD Monitor with the two row, 9 pin connector came out before 1991.
Radius FPD Monitors with the VGA type connector, has horizontal and vertical synchronization signals on separate pins/wires. The attached file (590-0029) is the pinout for the VGA style connector on the FPD Monitor (75Hz).
The older Radius FPD Monitors with the two row, 9 pin connector is a composite analog signal. In other words, everything is on one pin. Composite video is a single signal which carries luminance (brightness) component of a video signal, along with synchronization (horizontal & vertical) information, on a single wire/pin.
VGA requires horizontal and vertical synchronization signals to be on separate wires/pins.
There are three different types of Radius FPD Cards with a Vertical Refresh 67.139Hz, 69Hz or 75Hz. The 75Hz came out in 1991 with the VGA style connector. See attached Radius FPD Interface Card Table I made up.
View attachment 590-0029.pdf
View attachment Radius FPD Interface Cards.pdf
Correction on the last sentence. The 75Hz came out in 1991 with a VGA style connector on the FPD Monitor. The 75Hz FPD Interface Card that came out in 1991, should have a 2 row, 15 pin connector.
A Radius FPD card for the SE/30 would drive my Apple FPD with a slight amount of flicker - I assume the refresh rates were slightly off.
According to the Q&A I got off the old Radius website that was archived at xxx
Q: Can I run a 68Hz (Part # FPD01) on a Mac SE/30?
A: No. Radius did not manufacture an interface card for a 68Hz FPD for use with the SE/30.
P.S. The 68Hz should be say 68KHz.
