Graphite Airport Base
bibilit
68030
Just scored a nice Graphite Airport Base. ;D
Unfortunately,the card itself is an Orinoco Silver, not the Airport one.
But the base is powering up and apparently not suffering from the capacitors failure.
Thats right, they are indeed supposed to have a WaveLAN PCMCIA card inside, not an AirPort card.
I've still got my graphite base station here and in service. Great little unit. Its handy to have a device thats friendly with older Apple hardware.
If you want another wavelan card for your OS 9 PowerBooks.. I got one you can have for 10 bucks.. Works fine with the Airport Drivers
Thanks, already have a spare wavelan card, useful to get my 5300 on line (pretty slow but nice for a pre-airport powerbook)
Indeed, apparently, most Broadcom BCM 43xx chipset cards seems to be recognised as Airport cards.
Apparently, some were supplied with the Airport instead of the Wavelan / Orinoco, but should be a few.
there is a possibility to connect non-airport equipped computers apparently (using an Ethernet cable) anybody here using that setup ? (can be useful for a Powermac G3 or G3 Imac)
I am still trying to figure how to connect a non-airport compliant computer with the ABS.
I want to connect the ABS to an G3 Imac or similar, using a crossover cable, but unfortunately nothing seems to work right now.
