Gearing Up for Summer
Yes I tried MacHTTP 1.1...it crashed at the first connection. I also tried 2.5 and 2.6. They will not work under this mini system. Maybe because of the limited memory ( 2 MB).
I like httpd4Mac. It is very small and doesn't use much memory. But if anybody has more web server software for a Macintosh ...this is more then welcome!
Thanks for the advice!
I think Netpresence is complicated on a minimal system....maybe you are right with EasyServe. I have a copy and will try it. I thought it would not work, because it says that you need OT 1.1.1 minimum. No such thing on my Plus...only MacTCP 2.0.6.
I will let you know if it works!
My httpd4Mac server only reponds on HTTP 1.0 requests. All modern browsers seem to use only HTTP 1.1.
@arfink:Any particular reason why you need ProTerm on the Apple II?
Well, mostly because right now I'm using Modem.MGR and it seems to limp a bit. ProTerm would be more friendly to my native Apple II applications, especially AppleWorks. Mainly I would appreciate better terminal control and better uploading and downloading.
