Programming 68k code in Tiger???
All,
I got in my hands something I've for long needed - A genuine Macintosh programming book. This is Macintosh Programming Primer from 1989. So, I thought I would setup an environment in the Powerbook G4 I have. This would be convenient as I can then carry it around. I got the Classic environment installed in Tiger, but Think C gives me trouble. I have tried versions 3 and 5 and while they load the environment, and I can even create a project in V3 (but nothing at V5), the application is somewhat dead. None of the menus work at all. No response what so ever. I need top kill the Classic to stop the programs. Version 6 behaves a bit differently. The installer program fires up, says it needs to close all other programs and does so, creates a couple of directories but that's about it. Also a file "Compressed essential Dev. Set 1" is copied onto that directory, but it is not extracted, and after a while the installer just dies and Classic gives a dialog saying error in Finder. There is no visible dialogs at all.
I thought I could just decompress the Essentials file, but none of my programs (stuffit, unarchiver) recognise it.
Why Think C and not something different? I like to read a proper book while doing this sort of thing and this book is written around Think C.
Any advice or pointer into right direction is appreciated.
If you really want to use Think C, I'd recommend booting directly into Mac OS 9 instead of using Classic; under Classic, you'll have debugger issues, sample build scripts might not work, and anything with timing issues will have problems. You'll want to ensure you're using Think C 5 or 6; 6 will work better on Classic.
I was afraid of something like that. The issue with this powerbook is that to my knowledge this powerbook doesn't support booting to System 9 or older, just OS X.
There are special versions of OS9 for pretty much all G4s, I can't remember if they solved the issues on FW800 machines, but if your PowerBook doesn't have FW800, it can absolutely boot OS9.
I have no experience with THINK C, but I've found that starting a debug session in CodeWarrior IDE 4.1.0.3 (i.e. Pro 6) has a tendency to crash if ToolServer is running in native Mac OS 9, while it never happens in Classic. Also, the IDE debugger crashes on occasion anyway, seemingly for no reason, and restarting Classic is less invasive than rebooting the whole system.
This is a PowerBook5,6 - A1106. I has a FW800 port, and according to everymac.com it is not capable to boot OS9. Or at least I have not found a correct OS9 cd anywhere. I have some from garden, but none of those will boot.
There are ISOs from MacOS9Lives that might boot your PB (I haven't checked recently).
To echo the sentiments above, get yourself a Mac that can boot Mac OS 9 natively.
In essence, that is any PB under 1GHz or any Mac before 2003.
PowerMac G4s desktops are versatile, easy to expand, reasonably easy to repair and, best of all, reasonably cheap & easy to find. Get one of these and use that at home. If you want the portability, then look for a PB without FW800.
Since you want to program for 68K processors, a 68K would be a good thing to have. keep an eye out for an LC 475 (or Performa 475). These are great little machines, easy to expand and also relatively cheap. They can also run Mac OS 8.1, which is a plus.
I did solve the problem somewhat lazy and not totally acceptable way of Basilisk II. This gets me starting with this learning path. I'll be looking for a suitable laptop though...
There's nothing wrong with using emulators and other platforms. I do most of my coding and building in OS X / macOS, with 68K code compiled and linked in SheepShaver. Generally I'll test in Advanced Mac Substitute and SheepShaver before firing up Mini vMac if necessary.
100% agreed. For development, using emulators is extremely sensible.
Totally acceptable, this is how I do almost all of my dev stuff (although I use CodeWarrior because THINK C makes me want to tear my hair out for some reason).
