I drafted a prototype G4 cube heatsink for dual boards. I went ahead and sent it to JLC to make a plastic prototype to test fit and screws. If anyone has a dual and wants to try fit on their boards let me know and I will send the f3d/step etc or w.e files so you can edit the cpu contact stage. The cnc process is very costly >300$ for a copper heatsink custom milled, but aluminum is about half the price. I would really appreciate it if someone has a 3d printer that wants to go ahead and try a cheap plastic prototype to see if the screws will fit this weekend, if they are wrong maybe I can cancel my JLC order. As is custom I will hold off making files general-public until I know the dimensions are actually correct. Thank you!
