[in B&W] set at 6 / 550 Mhz / set it at 7 it did not boot / set it at 5 / 650
For B/W G3: 6=550, 2=500for Beige G3: 7=500, C=533
x Bus speed NewerTech PowerForce
Mult 66 100 Jumpers Dial
3.0 200 300 | - - -
3.5 233 350 | | | -
4.0 266 400 | - | -
4.5 300 450 - | | |
5.0 333 500 | - | | 2
5.5 366 550 | - - | 6
6.0 400 600 | | - |
6.5 433 650 - | - |
7.0 466 700 - - | -
7.5 500 750 - - - | 7
8.0 533 800 | | - - C (=12)
10.0 666 1000 - | | -
| = jumper
- = no jumper
LSBMSB MSBLSB Invert base10 Dial
| - | | | | - | 0 0 1 0 0+0+2+0 = 2
| - - | | - - | 0 1 1 0 0+4+2+0 = 6
- - - | | - - - 0 1 1 1 0+4+2+1 = 7
| | - - - - | | 1 1 0 0 8+4+0+0 = 12 (=C)
| = jumper 0 = jumper
- = no jumper 1 = no jumper
NB THESE NUMBERS ARE UNTESTED except as noted above.
Mult 66 100 Jumpers Dial Note:
3.0 200 300 | - - - E (14)
3.5 233 350 | | | - 8
4.0 266 400 | - | - A (10)
4.5 300 450 - | | | 1
6.0 400 600 | | - | 4
6.5 433 650 - | - | 5
7.0 466 700 - - | - B (11)
8.0 533 800 | | - - C (12)
8.5 566 850
9.0 600 900 - - - - F (15) jumpers unconfirmed
9.5 633 950
10.0 666 1000 - | | - 9
| = jumper
- = no jumper
" 10x ratio is not supported on all G3 CPUs,
9x is the max ratio on G4 7400 CPUs in most G4 ZIF upgrades
(and all Newer Tech G4s I've seen)" *
Temetka: any chance you could pop the top and check what the dial is set to?I have a 500MHz G4 that is just like that. I just kept turning the dial until the system profiler reported a speed of 500MHz. It's running in my 8500 with a ZIF Carrier card.ZIF / trim dial with numbers / speed setting / PowerForce by PowerLogix / positive match.
You might have the clip on backwards. If you look closely you'll see that the lowest point is not exactly in the centre. That point is meant to sit exactly above the CPU die. Try reversing it.I've just never seen one of those pad things before and the heatsink wobbles without it. I tried putting a little bit of extra bend in the clamp so it would hold it more firmly, but it still seems to be pushing down in the wrong spot... It holds the heatsink at a slight angle at the contact point of the processor.
It's not documented anywhere I've been able to find, but from the table above, there's only /edit/ four undocumented settings: Powerforce dial 0, 3, D (13) and F (15). They would correspond to:hmmm...is there a way to set these ZIFs to a 9.0 or 9.5 cpu/bus ratio?
?? | | | | 0
?? - - | | 3
?? - | - - D (13)
?? - - - - F (15) /edit/ now documented above
It may still be alive. Apple patched the ROM in the blue and white when the Yikes! was released so you couldn't just plug in a G4. Best machine to try would be a Yikes! since that is probably what it came out of originally.Just thought I'd let you know, the G4/400 (7400) I bought from IC-China is pretty well confirmed DOA. I tried it in the ZIF card and it didn't work but assumed it was the ZIF card being fussy. I tried it in the B&W today prior to donating it to a friend and it wouldn't boot in that either. I suspect it's fragged. It looks like it was originally fitted by someone with a rather too generous hand with the Arctic Silver. It was COATED in it. Either way it doesn't work![]()
I'll update above with the F dial setting and the deduced, untested jumper settings.is there a way to set these ZIFs to a 9.0 or 9.5 cpu/bus ratio?
No shame in it sir [I'm ashamed to say i googled "funkymonkyPiE" and it brought me here.
Ah... your circle of interests overlaps mine./ overclock two Wallstreets / Opcode Vision / Studio5 MIDI interfaces / M-Audio Delta 1010LT Audio Card (10 channel)
Don't ya love the net [/ charts from here / links / a page in french / charts from a japanese site that is no longer available.
Remind me to send you a Tshirt when I get around to making them up.My main project mac
