I recently bought a nonworking Mac Portable as a restoration project, and the first thing I decided to do was replace the battery. I know some people have had luck using off the shelf rectangular 6V lead-acid batteries and modifying the Portable's battery holder, but since the original cells are still made, I decided to do some looking around at the EnerSys catalog (EnerSys is the successor company to Hawker Energy, who in turn was the successor company to Gates Energy Products, the original pack's maker).
What I found is that EnerSys part number 0800-0102 is an exact replacement for the three 0809-0004 cells in the original pack. This is 3 new EnerSys batteries just like the originals, already wired in parallel. They're held together with hot-melt glue instead of shrink wrap, but the glue doesn't interfere with the plastic pack. There's a plastic strip on the top held on with some hot-melt glue, but that's easy to pop off and then all you have to do is remove the gold terminals, foam tape, and plastic spacers from your original cells, solder or spot-weld them to the terminals on the new pack, bend over the tabs so the Portable's battery lid will fit, put the plastic spacers and foam tape back on, and reassemble. This pack can be found in the US for around $40-50, just search the usual retail suspects for the part number.
As a side note, after replacing the pack, my Portable boots, but has no sound and the floppy drive eject doesn't work. Probably time to change some caps and re-grease the FDD.
