I'm cleaning up the plastics on a G4 and thought about removing the paint from the inside of the side panels and either leaving them clear or painting them another color. Then I realized that won't work for the apple in the center. Is the apple covered by a separate piece of plastic that can be removed? I don't want to just paint the outside of the case so if there's no way to get to the back of the apple and repaint it then I'll just polish the plastics and leave them the original color.
