ATX to /PFW Conversion PCB Creation
IlikeTech
68000
Hello everyone! I am in the process of converting a Quadra 650 Logic Board to use an ATX power supply. There seems to be quite a bit of interest in Custom Cases, so having the ability to use smaller power supplies would be useful. I can create a small PCB. A quote from seeed showd 4 dollars and 90 cents for 10 boards under 10x10. Rather than using a chip with 4 inverters, I figured I would just pick up single inverters in a surface mount package. I would also use surface mount resistors when possible. Let me know if you are interested in one!
